Window not fully closed alerts
To reset the window's calibration try this...
1. make sure the window is clean from any debris
2. roll the window all the way down
3. hold the down button for 10 secs
4. roll the window all the way up
5. hold the up button for 10 secs
6. (optional if needed) roll the window all the way down and hold 10 secs
This should help reset the regulator. It fixed mine. :)
Reactions: David29
David29
2,326
2,001
DEDHAM, MA
Oddly, today (August 31) my car (2015 Model S, AP1) is getting alerts that the sunroof is not closed (although it is) but the phone app says it has not updated since August 25 and does not show the current software version that was installed last night (which I assume is 2020.32.3, since that is what looks to be next for AP1 cars from the firmware tracking log) -- I am too lazy to walk out to my car, which is some distance from my condo, to double-check right now. So there is enough connectivity to send me annoying/incorrect alerts, but not enough to tell the phone the other details of the car's status, including the current software version. (And yes, my MCU memory has been replaced.)
I have now gotten update 2020.36.3.1 and no longer seem to be getting the bogus alerts. Whether or not it was resolved by the newer update or just "went away," I am not sure.
Snowstorm
1,575
1,508
Ontario Canada
Which model does this apply for?
JimBob 909
Little Red Raven
Sep 16, 2019
206
187
Southern California
bktiger86: I had rec'd one or more windows open errors and tried the reset you cited..It must have worked, no more window open messages. Thank you very much.
Reactions: David29
Mehdi
42
29
Oregon, USA
@bktiger86, @GeorgeSymonds,
Thanks for the procedure on window calibration. The issue on my car seem to have been resolved... at least for now.
I also have received a couple of notices about the sunroof being open a couple of weeks ago. Checking the sunroof confirmed that it was fully closed. Since the roof is electronically/software controlled, I wonder if fully opening and closing would solve the issue... when/if it happens again.
Today, about 20 minutes after exiting MY, I received an alert that my passenger window was open. Went outside to check it and it was indeed open, but apparently had just opened because it was cool and rainy and very little rain had come into the car. Anyone have experience with windows opening themselves (perhaps a glitch in the “vent” control)?
MrKool
253
152
Virginia
Am I rolling the window down on auto or using the button to manually roll it down and up all the way? also I let go of the button after it is down and then press down for 10 Sec or continue to press the button down while it is going down and keep it pressed fir 10 extra seconds?
