Window opens when Wet
chengka
118
110
Denver, CO
I ran into an issue and I wanted to share.
When I washed my car at home, I noticed that the window behind the driver was in the "door open" position. I thought, how could I have left it open. I tried to close it and it would not close. Also noticed the car thought the door was open. I finished washing and moved into the garage. I tried everything I could think of but the window would close.
I opened a service request in the app. While I was putting away the car wash stuff, I noticed the window closing and opening in rapid succession. Once closed I tried the window recalibration, that seemed to fix the issue. A day later Tesla contacted me and stated there was a known bug that caused the door to appear open when the window was not calibrated. I replied ok, but I still had concerns, since when the door is open the car will not lock nor power down.
Service scheduled for 10/13. I washed the car 10/12 and sure enough the windows opened again. Updated the service appointment with the details. The tech arrived and asked me to hose down the window.. After 1 minute the window opened. He started taking the door apart. Turns out he found a similar issue in their DB. The harness which passes through the B pillar was not installed correctly and allowed water to leak into a connector. That lead to the odd behavior. There was already corrosion in the connector(1,800 miles, dry in Denver except car washes!), so he ordered parts and they will replace them 2Nov.
Hope this helps anyone who may experience the same issue.
Tiger
1,703
1,574
Estonia
Wonder if the door would open while driving and/or with childlock activated (or when locked in park, can thieves get in using water?). Hope it does not warrant a NHTSA recall.
jdr93
135
71
wooded vermont
Glad they found the issue.
What is the window calibration procedure?
glad that the issue was found and will be fixed, but even more glad the issue was published here. i ran the car through a touch-less (high pressure) wash soon after taking delivery and noticed a problem with both rear windows going down to door opening level. did not connect the wash and the windows until the post above.
and yes
what is the window calibration procedure, please?
great2b1
New Member
Nov 6, 2020
laguna beach
i
i had same problem, tesla said there was service bulitin and replaced wiring harness
MikeBur
ManualPilot
Dec 8, 2014
1,373
737
Seattle, WA
Hey all, can you give your VIN range or link to the SB please? Ours is < 10k and a couple of times, in rain, we’ve come back to open passenger side window.
Never happened on 3, so just put it down to hitting window switch on drivers side on exit and not noticing... will try the hose pipe.
kmcgoey
19
14
Thanks for your post. I had the same exact issue and the Tesla service dept told me they couldn’t find anything wrong after having it for 5 days. I sent them your post and told them to look again. Apparently, the third technician to look at the car found the harness wasn’t installed correctly on the 6th day and fixed it. Kind of sad that I had to do all the research to find the issue on my own. But thankfully you at least made that possible.
Pianewman
1,480
1,059
Fort Worth
I'm glad they found your problem.
Over the years, I have "trained" a ton of techs and parts counter guys, all makes of autos. There's SO MUCH TECH involved, it's difficult for them to keep up. It's not an excuse, but a reality. Tesla has ramped up so rapidly that they're just not able to keep up. How can a tech have any real experience when the technology is so new? In addition, there are continual "running changes" in production that simply change things around.
At one point, my servicing tech at a reputable VAG dealership was calling ME for advice about the infamous "clean diesel." The diesel owners on the TDIClub site knew a LOT more than most dealer techs.
Reactions: kmcgoey
kmcgoey
19
14
They should search this site! lol. The other issue is they didn't even read your post when I sent it to them. I made them read it when I showed up in person to pick up the car after they told me there was nothing wrong. Not being able to get someone in service on the phone is pretty annoying.
