WINDOW SEALS
NGO FEAR
20
Just wondering if anyone has had any issues with their window seals?
Moisture seems to be getting through after I wash the car. my car is a March18 build.
Reactions: juice15e
AEdennis
2,719
938
I've reported similar and it was supposedly addressed. I haven't washed since, but now notice more noise AND have to go back in as the rear ones are now pinched.
JPP
3,070
1,296
SF Bay Area, CA
Routine for me in both Model S. A bit of moisture creeps into the groove in the rubber gaskets, then evaporates and causes the fogging. No real water intrusion. Just open the doors and wipe the gaskets.
Reactions: Doanster1
mbhforum
1,223
627
Long Island, NY
I have this car on my 15 model in taillights and Windows. I noticed it this past week when I tinted my windows and saw moisture after I washed my car in my driveway. Would the Service center actually address this? I’ll likely ask them to when I bring my car in for that recall later this year.
Doanster1
1,034
558
Oregon
Not the windows since there is no actual water intrusion. Par for the course with frameless windows.
Tail lights it’s a maybe. I’ve read where some people said the SC stated it was “within specs” and that the water evaporates. Worth a try to ask IMO.
cmaster
240
76
United States
It's fine as long as the rubber gasket doesn't break. Condensation normally happens and it gets on the inside of the window a little. If you inspect the seal, it's rounded and not square. So, you would expect the condensation to build up underneath it a little.
KempStep
New Member
Mar 25, 2018
Sacramento, CA
We also noticed this today, when washing our Model 3 (delivered March 24).
There does not seem to be adequate seal to prevent water going down inside the doors.
If after washing, you roll the window down and then up again, there will be a sheet of moisture on the glass that you have to keep wiping off.
We rolled the windows down and up multiple times and there was still moisture.
I called Tesla and have a service appointment setup.
