I will be applying window tinting to side and rear glass on my car. Since the rear-view dash cam will be installed on the rear glass, is it better to install the tinting first or the dash cam?
Thanks. Looking forward to your pics.I have XPEL tint and a Thinkware F770 the rear is 1080p and is not affected by the tint at all, it looks great, night or day.
Hope that helps.
I'll try and grab a few photos from it driving at night, but take a look at the side by side comparisons done, I could see cutting a very small circle at the camera point and you would not even notice it though.
I use the BlackVue DR650S 2Ch. I installed the camerea after the tint but found that the picture quality is not as clear. So I carefully cut out a square from the tint and now am satisfied with the video quality. So I would place the camera first then have the tint shop tint around it.
I found this post while general dash cam search and thought I'd post a picture of mine. The angles are off as its a temp install, but the front has a UV clear tint and the back has 15% on top of a clear UV (previously done at clear). Ceramic tint. Very bring sunny Florida day, mid day so sun is at peak. This is where the polarized lenses would work great.Can you share a photo?
I didn't cut the tint at all. I'll get a picture from the outside around the same time. I'm doubtful you can see much of it. I can't see [the rear cam] at all from the drivers side.Thanks. Any chance you can grab a photo from the outside of the rear camera area where you did your cut out of film there? Curious if the area of film cut is noticeable from outside the car. Video grab look good.
Around 2pm. View from the outside and insideThanks. Any chance you can grab a photo from the outside of the rear camera area where you did your cut out of film there? Curious if the area of film cut is noticeable from outside the car. Video grab look good.
