I am starting to suspect that there is something amiss with my MS’s rear right window. At random times I have found it to be a crack open. I thought it was just somebody hitting the switch by mistake. But yesterday I caught it in the act: sometimes the window won’t go back up after lowering when the door opens. Not only that, if you open the door repeatedly before manually closing the window, it will keep going further down every time.
The trick, as it tends to be with these things, is that it does not happen every time and it doesn’t seem to follow a predictable pattern. So taking it to the SC is kind of rolling the dice.
Anybody out there has had this issue? I am curious to know what the fix was, so at least I can sound a bit smarter if I take the car to the SC and the problem is a no show.
Thanks!
Thanks!
