Windows/Doors won't open in cold weather
Discussion in 'Model S: Interior & Exterior' started by mrjedistud, Jan 12, 2017.
  1. mrjedistud
    mrjedistud Member
    New York
    Hey guys. Anyone else experience this.
    In freezing weather I couldn't open my doors. After playing around I realized its because the windows (which normally open slightly when you pull the handle) were not dropping down. This in turn caused the windows to get stuck on the chrome lip. I am assuming that either the cold or possibly ice froze up some of the window mechanics in the door itself. I tried preheating the car and it helped on one door, but the others were still stuck. Not a huge deal as the weather eventually warmed up and I usually drive solo, but was a bit annoying.
  2. scottm
    scottm Active Member
    Canada
    maybe a Model S: Interior & Exterior story?
    moderator could help move it
  3. Max*
    Max* Charging
    NoVa
    I had this happen once or twice when it rained and my car was parked outside, the windows would freeze, and I'd have to either pull a little harder (the chrome is weak, so the window will go under it with a little force) or chisel my way out.
    There was another thread, someone said they had it on another frameless window car too.
  4. NovemberXray
    NovemberXray Member
    Portland, OR
    Yep, preheat and use a credit card to slide down between glass and door, this usually will clear the thin layer of ice and free the window.
  5. CinRedMan
    CinRedMan Member
    Dayton, Ohio
    Having the same issues with my MS. Note, I also had this problem my BMW 330Ci (Convertible), so this really isn't unique to Tesla.
    I do question the "quality" of the material Tesla is using for the glass sweep. Now, with this said, the recommendation of using a CreditCard to break things free is great advice. DO NOT hit the top edge of the glass with anything; you will not like the results :-(
  6. Brass Guy
    Brass Guy Member
    Holbrook, MA
    Ya, this happened to me too.
    I was thinking about it as I went to open a door though. I thought I'd read that someone opened a door forcing the window under the trim, then when the door was closed the window smashed. I don't know if this is true but I won't take any chances.
    I popped the driver's door open and didn't close it until the window control worked; then worked the rest of the windows.
    I'll have to try the credit card trick next time, good idea!
  7. mrjedistud
    mrjedistud Member
    New York
    I'm reviving this thread. 2 years later and still have the same issue. Does anyone know if Telsa fixed this in later models? Mine is a 2013. MS
  8. Videofrank
    Videofrank 2015 P85D
    New York/New Jersey
    Nope. Also not isolated to Tesla at all.
    Preheat the car and use a credit card to swipe between the window and the window sweep near the door frame. Works like a charm.
  9. scottm
    Canada
    I keep a proper ice scraper in the bonnet or boot .. (I just like saying those words sometimes) .. which can be opened more easily when car is frozen.
    After all these years of driving an EV and still having to deal with ICE issues. Just can't escape it!
  10. dabbler
    dabbler Member
    Toledo, OH
    I too have been keeping a small thin plastic scraper in the frunk or truck. I use this anytime I think that the windows are frozen to the weather stripping. Do all four windows before even attempting to open doors. I owned a Land Rover Evoque and had the same issues.
