Windows that don't roll all the way up
Discussion in 'Model 3: Interior & Exterior' started by CarbonFree, Mar 18, 2018.
  1. CarbonFree
    CarbonFree Member
    Seattle
    Today at the carwash I noticed that my drivers side door did not roll all the way up. This could have been user error, or it could have been the car. This is the second time I've wet the interior of my car unexpectedly, though, so I wonder if anyone else has experienced this issue.
  2. Snow Drift
    Snow Drift Pirelli P Zero Winter
    Long Island
    Did you close the door hard? If you don’t close it hard enough the window will stay open slightly.
    Normally when you open the door it rolls down slightly. When you close it waits a second and then rolls up to seal. This is a very common action for coupes and convertibles that don’t have framed doors.
  3. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Car wash? You should be washing by hand.
  4. CarbonFree
    CarbonFree Member
    Seattle
    It's more of a car wash bay, for self washing.
    The door was definitely closed, but whether it was closed "hard enough," I can't say, besides that fact that the door was flush with the rest of the car, and the car had locked itself.
  5. CuriousG
    CuriousG Active Member
    Elk Grove, CA
    A piece of my seal in the window of the driver came apart recently. First it stuck outside the window (about half an inch) and it make it sticky so the window would get stuck a bit when trying to roll down. I did eventually turn the sticky side that was protruding out to go back in but when I washed my car today, that piece just broke off.
    My rear passenger window wouldn't roll up and stay when I got my window tinted. You would start to roll it up and when it hit the top, it would roll back down again. This was eventually fixed by gentry using the window button to move it back up slowly and eventually it reached the top and haven't had an issue since.
  6. CarbonFree
    CarbonFree Member
    Seattle
    I'll be darned, it did it again. I'm not sure of the cause, but I don't really like the car to lock (or drive) with a window partially rolled down—at least, not from the car's own doing. Some kind of alert would be nice.
  7. scaesare
    scaesare Well-Known Member
    NoVA
    It's been reported that if you roll the window all the way up with the door switch, and then hold the switch in the "up" position for 30 seconds, it should recalibrate the window position.
    (Note I don't know if you need to release the switch in between the above two actions... if one doesn't work , try the other).
