Windscreen/windshield squirter reboot problem
Discussion in 'Roadster 2008-2012' started by Slackjaw, May 15, 2012.
Tags:
  1. Slackjaw
    Slackjaw Member
    Central NJ
    So my wiper fluid ran out (yeah, embarrassing) and I refilled it, and now it won't squirt at all, even though the reservoir is full. Any suggestions? I tried cleaning the nozzles.
    I know TEG, Nigel and Bonnie will all have plenty of fun with this but look, people, it's a real problem and it could happen to anyone. :redface:
    Thanks in advance.
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Running out of fluid is probably not the root cause; you can get a clog in the outlet from the reservoir or in the tube. See if you can remove the tubing from the tank and blow it out with some compressed air.
  3. bonnie
    bonnie I play a nice person on twitter.
    Columbia River Gorge
    #3 bonnie, May 15, 2012
    It might be a snake.
  4. strider
    strider Active Member
    NE Oklahoma
    You might need to prime the pump. Get a friend and cover the nozzles w/ your fingers. Have your friend activate and hold the washer. You should feel some pressure on your finger. Gently release and see if liquid is coming out. If not, cover it again. Try this a few times and you should get fluid.
  5. Slackjaw
    Slackjaw Member
    Central NJ
    Thanks, I'll try this first. It does remind me of the time MPT "accidentally" squirted me in the face with wiper fluid from my car while checking something in my car at one of our meets...
  6. vfx
    vfx Well-Known Member
    CA CA
    Mine just ran out (or maybe clogged) We have very hard water coming out of he ground that makes sinks and showers dry white. I'm thinking distilled water.
    Once a friend bought some "windshield wiper fluid" from a autoparts store. It ate his paint. I'm sticking with water.
  7. bolosky
    bolosky Member
    I had my washer fail twice from driving on a go kart track (and the resulting very fun high G turns). It made the reservoir move enough that it crimped the tube.
  8. cinergi
    cinergi Active Member
    MA
    Mine ran out and it took a *LONG LONG* time for it to start pumping again. It just takes a while (and IIRC Tesla told me that's expected because I reported it as broken and they told me to just keep running it).
  9. NigelM
    NigelM Recovering Member
    Northern Virginia
    Elon has a cross-company fix for this...
  10. bonnie
    Just waiting for TEG to weigh in now.
  11. Slackjaw
    Slackjaw Member
    Central NJ
    Strider's fix almost worked for me; I get pressure and then when I take my fingers off the nozzles it squirts but only once. It does seem to be consistent with the pump having air in it (aka "needing to be primed"). I get the same problem with my espresso machine. I'll try a more protracted run later; I didn't try for long this time because my assistant is only 4 yrs old and was beginning to lose interest [he can't reach the pedals to put the car in drive, BTW]. I'm also worried that I'm going to burn my paint off with the wiper fluid now (previously was distilled water). Thanks for the suggestions.
  12. tdevince
    tdevince Member
    Columbia, MO
    You probably have algae growth in your reservoir clogging the outlet. The OEM fluid did not have enough alcohol to prevent growth. This happened to me as well. Simply remove the tank and clean the screen and refill with normal fluid. Prime the pump and you're good to go.
  13. Doug_G
    Ottawa, Canada
    I think the OEM fluid is water, or at least it used to be. Fortunately I was smart enough to replace it with proper washer fluid before the first winter hit. Other owners had their sprayers freeze solid. California companies, I tell ya!
  14. jerry33
    Texas
    It's no better in Texas. The fluid is coloured blue but freezes when the temperature is below 40.
  15. NigelM
    Northern Virginia
    This story was in today's paper:
  16. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    In Central California, it was the coldest. I lost all of my citrus, and cherry trees due to cold.
  17. slcasner
    slcasner Active Member
    Sunnyvale, CA
    Way OT, but I thought cherry trees need winter chill hours in order to produce.
  18. Lloyd
    San Luis Obispo, CA
    They froze all the way through, now dead. 1 of 5 survived. 4 avacados lost, 2 orange, two limes, two grapefruit.
  19. cinergi
    MA
    They changed the fluid manufacturer at some point and whatever it was would freeze very easily. Mine froze solid the winter before last. When I complained about it, that's what I was told.
    These days I use the Rain-X fluid.
