windshield distortion
Discussion in 'Model S: Interior & Exterior' started by Bruce, Jan 2, 2013.
  1. Bruce
    Bruce Member
    just got my MODEL S and love it However have noticed distortion at the bottom 1 inch of the windshield has anyone else noticed this? Seems odd ... was thinking it might be the coating they put on it has caused this?
  2. olanmills
    olanmills Member
    Yup it's on all of the cars. I assume the glass is curved or something down there. It doesn't really bother me.
  3. DrComputer
    DrComputer Active Member
    Sherman Oaks, CA
    The bottom distortion is a known problem (design flaw, unwanted manufacturing defect, insert best euphemism here) with the glass. Some windshields are worse than others. The average is about inch of distortion. There is another flaw that a few people (including myself) have had with the lamination between the two pieces of glass that distorts the forward view. I had my windshield replaced because of this lamination problem. There have been other people that have had the windshield replaced because the bottom distortion problem was more like 2-3 inches and not just the "normal" 1 inch.
  4. FlasherZ
    The distortion gives my wife a headache every time she rides in the car. Ever since she was in a major accident (Indianapolis Sugarland stage collapse), the effects of her double vision / missing vision spots are exacerbated by the windshield's distortion. It's something that dissuades her from riding in the car.
  5. dcopperfield
    dcopperfield Member
    Bothell, WA
    These aren't flaws. According to my neighbor who is an engineer for Boeing, they are intentionally built that way to distort glare from the car hood while driving. He said most high end cars have that and its fairly common-
  6. DrComputer
    Sherman Oaks, CA
    Some cars have had a larger distortion area than others. If yours is very large you can discuss it that your service center and see if they can replace the windshield. You can also get some black tape or paint and black out the distortion area.
  7. bbmertz
    bbmertz Model S: P4909
    Los Angeles, CA
    As I just posted on the TM forum, I discussed the front windshield distortion issue with a Tesla service advisor today. He indicated that while the distortion was not intentionally designed, it is not considered a defect. Tesla would consider replacing the windshield if the distortion was excessive, but would not guarantee that it would be any better afterwards due to the curvature of the windshield and since it cannot be observed until after it is installed. Since someone on the TM forum mentioned that the distortion was worse after he had it replaced, I am going to stick with my windshield as is, since it only appears on the bottom inch in my car (although it is annoying).
  8. Zapped
    Zapped Model S - PURE EV
    YEG <-> PSP
    Haven't seen this since my 1971 VW Beetle got curved windshield.
    Too bad the black spotted area already present does cover more of the lower glass area. Difficult DIY job IMHO
  9. bob_p
    bob_p Active Member
    The distortion doesn't seem to be as noticeable when the seat is adjusted to a higher position.
  10. smd
    smd Member
    Lafayette, CA
    That was my solution as well, and you get a better view of the road ahead with the higher position.
  11. William3
    William3 Member
    I tried the higher seating position, noticed that my view out the back window got a lot worse.
  12. Zapped
    YEG <-> PSP
    There's some distortion out the back window also
    I noticed the lines on the road have a bit of a moving wave
  13. jerry33
    Texas
    Unless you roll 18 or better on a d20, hatchback windows always have distortion.
  14. 85KWh
    85KWh Member
    YYC
    My Model S also has the distortion. And unfortunately, within the first week has suffered a very significant crack. It appears to have started at the bonded edge on the lower passenger side and is making its way across to the middle. Has anyone else had this problem ? There is no other evidence of damage and certainly no chips to speak of. Seems to be an installation or flexing problem at the edge.
  15. Jeeps17
    Jeeps17 Cath Jockey in a P85
    Montreal, Canada
    There is already a thread on this topic. Hope it helps!
  16. Getting Amped So
    Seattle, WA
    I don't understand why TM just doesn't cover the distortion with a black opaque border and dot transition pattern. Does the S windshield have this already?
  17. Zapped
    YEG <-> PSP
    Yes, just could be a little higher up.
  18. Borgie
    Borgie Member
    Connecticut
    I just picked my car up today. Drove it the approximately 60 miles home. Didn't notice the distortion at all. I just took my wife out for a ride/drive. She noticed it immediately and said "If you're looking for a reason for me not to ride in or drive your car, you found one!" I'm going to experiment with a higher seating position for her, as I think the lower perspective is the problem. (I'm 6'1" and she's 5'6"). I do not believe this is an intentional design "feature." I've owned many Porsches, BMW's, Audi's etc. and I've never seen this feature.
  19. sp4rk
    sp4rk Banned
    Schaumburg, IL
    Are you sure you didn't do this on purpose? Like raise her seat? To prevent her from driving? :)
  20. Borgie
    Borgie Member
    Connecticut
    I will have no comment at this time. :cool:
