windshield washers not working
scottm
Legacy account
Jun 13, 2014
3,070
2,233
Canada
First, be sure you are pushing the button on the left stalk. Pressing the right stalk button is park... for newbies this happens.
Did you top up with water and weather change to freezing? Your washer lines are frozen.
Is ice blocking your jets? The wiper system in the car has very little clearance.
Tips: there is a wiper service mode to park wipers mid screen. Clear your ice.
Open the frunk, and you have access to all the ice.
Do not try to lift wiper arms up more than an inch from the screen.
Jan 12, 2015
84
0
orillia
Well I stopped at a gas station and looked then I went to the car wash not frozen everything looks normal just very little pressure.
And they were never that good in the first place squirter always just barely got to the windshield even when it was zero out
scottm
Legacy account
Jun 13, 2014
3,070
2,233
Canada
Could be a pinched line, if all jets are weak.
If just one or two, they could be misaligned or clogged (dirt). Use a pin to clear them.
mibaro2
959
Georgetown, ON
Normally the windshield washer spray should go pretty far up the windshield. I haven't had any problems even with the cold weather we have had this past week.
If the windshield washer container is full and ScottM suggestions don't work, I'ld call the SC to get it fixed.
megawhizz
43
11
Detroit, MI
Make sure you are pressing the button in all the way (2 stops) - the first stop just activates the wipers, second stop is to activate jets. Are you hearing the pump's whirring sound?
Reactions: fasteddie7
mknox
10,103
1,866
Toronto, ON
Be sure to use the best anti-freeze you can lay your hands on. Remember, there's no ICE up front to keep things warm. I was using -45 degree stuff and when it's really cold it comes out kind of thick and doesn't spray as far. I now use some -49 degree stuff that is quite a bit better.
Karma
104
15
Safety Harbor, Florida
I did the same thing the week I got my Tesla, and promptly felt like an idiot. Short press for wiper sweep. Full press for washer fluid. You won't break it by pressing in further until you feel the "click"
scottm
Legacy account
Jun 13, 2014
3,070
2,233
Canada
So true, I used typical grocery store -35C blue stuff and it becomes ineffective at around -15C... stopped spraying at all.
I think Costco sells stuff good to -45C (I think, and it's not blue but some other color - green?) Which reminds me need to pick some up.
The heated nozzles with winter package are pretty much useless and cannot correct the situation of fluid gel up / freeze.
Need to park in heated garage for a few hours to thaw the lines and nozzles.
scottm
Legacy account
Jun 13, 2014
3,070
2,233
Canada
I know I know, just haven't gotten around to adjusting them. Just thought it was crappy placement from the factory
It's really hard to dial in a proper spray pattern and there's very narrow margins of tolerance of getting the spray from the nozzle to the glass without hitting the wiper arm or hood sheetmetal... Poor placement of the nozzles. I would have much preferred they mounted the nozzles on top of the hood near the cowl rather than on the underside of the hood. I do not think the aerodynamic hit would cause any less range for the car. It comes down to a cleaner aesthetic hiding them under the cowl, at the expense of poor function.
Form over function.
Oh, Elon.
I am very close to getting the drill out and retrofitting a proper set of nozzles on top of the hood.
But before I do that, I want to see if I can get wiper arm mounted nozzles ... these would be best.
Reactions: Tezzie
Scott Franco
27
16
San Jose
Hi,
I read through this thread completely (used to work, makes the motor sound, only use proper wiper fluid in reservoir, etc). I have cleared this on other cars with a pin. However, I can't see where the opening is. It seems like the wipers themselves have the squirters, because there is a tube running up them. It there a picture showing where the nozzle is?
Thanks,
Scott Franco
scottm
Legacy account
Jun 13, 2014
3,070
2,233
Canada
@Scott Franco wait WHAT!? Are you talking about model S? Tubes up the arms would be news to me, and a welcome thing for new buyers. Has Tesla finally addressed this on new model S's coming out now, how old is your car ??
Tubes up arms on my model 3 is far better than the model S fixed squirters under the hood.
I'd want to retrofit these onto my old model S...
Accentcreate
79
29
France and Australia
They are adjustable...
Just how are they adjustable.
I have a new Model 3 and the spray does not wet the area in front of the driver. I looked in the manual and it says they are set in the factory and nothing about adjusting.
Our nearest service centre is some 400 km away, so not worth a trip for this,
Would like to solve it myself if possible.
