Thanks for the update.Hi all,
sorry for the delay, haven't been on here in a while.
yes - it needed a new wiper assembly and new wiper arm (the latter only because the black coating was scraped off, no mechanical need to replace it). Unfortunately they didn't seem to think a replacement bushing was possible.
the new wiper assembly was £124 ($160) - I don't remember what the arm was but less than £50 I think. I just fitted it myself as it's pretty easy. I imagine (and based on @AustinP post above) the labour is a lot more than the parts.
Tom
Hi all,
Tom
you might be lucky if still in warranty - you really have managed to wear away the bonnet there! Mine has a little wear on it but nowhere near as bad so it's not noticeable. I was outside warranty when it happened so I wasn't in any position to get a new bonnet, but you should push for that as well as the wiper mechanism and damaged arm.Hi all,
Just found this post searching for an issue I'm having and adding my experience for the record.
My car has about 100k km (late 2017) and I just noticed it now.
Unfortunately, by the time I noticed the issue, the wiper has taken a significant chunk out of the edge of the trunk / boot.
Have to say that this looks like a design flaw that Tesla should be covering.
I'll contact Tesla now and will update here when I hear back.
Any update? I just discovered the exact same issue with a significant chunk of my hood missing.Hi all,
Adjust the hood hinges and the problem will resolve.Any update? I just discovered the exact same issue with a significant chunk of my hood missing.
It’s caused by worn out bushing causing excessive play. Only cure was a replacement unit. Adjustment of the hood would do little good.Adjust the hood hinges and the problem will resolve.
Hi all,
