Windshield wiper issue in auto mode
Discussion in 'Model 3' started by kaoru, Jul 24, 2018.
  1. kaoru
    kaoru Member
    Ottawa, ON
    It seems my M3 windshield wipers work fine in manual mode. However when put into auto mode, they are very jerky, inconsistent with the swipe. It’s not the blades itself. Anyone notice this?
  2. kaoru
    kaoru Member
    Ottawa, ON
    Here’s a video of the issue.
  3. PoitNarf
    PoitNarf My dog's breath smells like dog food
    NJ
    Interesting, I haven't experienced this with my Model 3. Definitely seems annoying though! I'm sure a software update could address this.
  4. Lasairfion
    Lasairfion Member
    UK
    #4 Lasairfion, Jul 24, 2018
  5. davedavedave
    davedavedave Member
    NoVA
    Did you happen to put rain-x on your windshield? It looks like your windshield is hydrophobic. I did and had similar results to what you’re experiencing. It took a LOT of scrubbing to get it off. I tried isopropyl alcohol, magic erasers, clay bars and rain-x “extreme clean”. The latter two were most effective.
  6. StellarRat
    StellarRat Active Member
    Pacific
    If you have RainX on you windows your wipers really aren't that important in my experience.
  7. davedavedave
    davedavedave Member
    NoVA
    On the Model 3? I think the rake angle makes a big difference, and I really didn’t like the chattering and screeching when injust wanted a quick wipe. Disclaimer - Northern Virginia is like a Pollen-Apocalypse! YMMV....
  8. StellarRat
    Pacific
    I guess I'll find out this Fall. Right now, we wish there was rain here.
  9. KFORE
    KFORE Member
    Detroit, MI
    I had the exact same issue. I simply cleaned the wiper blades with isopropyl alcohol and a microfiber cloth and it completely solved the issue for me.
    Just put in your wipers into service mode, grab a MF cloth and some isopropyl alcohol, and you should be good to go.
  10. kaoru
    kaoru Member
    Ottawa, ON
    Yes, my windows were treated with Ceramic Pro Rain coating but that irrelevant. If watch the video, using manual mode at any speed the wipers work smoothly. Only auto mode causes a problem. That means that the coating is NOT a problem.
  11. kaoru
    kaoru Member
    Ottawa, ON
    True enough but on the Monday Ottawa broke a record in rainfall, 43 mm in a couple of hours. No amount of hydrophobic coating will bead that away...
  12. kaoru
    kaoru Member
    Ottawa, ON
    Wipers smooth in manual mode, jerky in auto mode... it’s not the blades. It like the auto mode is sending signals (to wipe, increase/decrease speed, etc.) during a wipe causing the behaviour.
  13. KFORE
    KFORE Member
    Detroit, MI
    Yeah, I had the same issue. I think auto mode uses less power or something, so anything that causes too much friction causes stutter? I don't know. All I know is, after I thoroughly cleaned the blades, the stutter immediately disappeared.
  14. Snow Drift
    Snow Drift Slip Start: [Activated]
    Long Island
    This 100% worked for me. Thank you for the suggestion!
  15. turtlesz
    turtlesz Member
    Southern California
    I'm having the same jerky movement in auto mode but smoother in manual. Tried to wipe blades with isopropyl alcohol but still the same. Any fixes discovered?
  16. Tikore
    Tikore New Member
    Coral Springs
    Any fix yet? Same issue here.
