Windshield Wiper Settings
Hitman007
364
141
Florida
So I am trying to figure out if I have a problem or if this is normal. When I put the wipers on the first delay setting with the far spaced dots, it hardly ever activates. Only when my windshield is almost completely covered with rain will it activate once and then just sits there until almost no visibility again. When I move to the second setting which is the closer spaced dots you would think it would be more sensitive. NO! Its slightly better but does not activate until almost no visibility . Am I missing a setting somewhere or do you fellow owners have the same issue?
vandacca
ReActive Member
Oct 13, 2014
3,371
2,202
Hamilton
I agree, the "rain-sensing" wipers are not very good at detecting when to start. I have my "default" position set to the location before manual and switch to manual when I feel I need it. I have found that it sometimes stays on too long when in this default setting, so I sometimes have to go to a lower setting (dots spaced further apart) by rotating towards driver.
Nerdy_Engineer
Brett - The Nerdy Engineer
Sep 22, 2016
208
236
Colorado
It doesn't rain much here in CO, but mine seem to work fine. If it's a really light drizzle (you don't get those in FL), then it'll take a while before the wipers activate, but they still do. When it's actually raining here (equivalent to a light drizzle in FL), they work just like normal wipers. Maybe try testing it with a hose.
Saghost
8,216
7,000
Delaware
I've only had it in a couple rainstorms so far, but I tend to agree - I wish I had a setting more sensitive than the more sensitive of the two.
At one point in intermittent light rain, I took to tapping the end button to induce single swipes.
Reactions: FarmerDave
Zeek
13
7
Glenview. IL
Agreed. The wipers seem to be somewhat sluggish especially compared to other high-end vehicles that I suspect we've all owned. The good news is this would be an easy fix if addressed by Tesla.
earlyretirement
Model X 90D
Jul 13, 2013
254
93
San Diego, CA
I totally agree. It rained for the first time in MONTHS here in San Diego the other day and I thought the wipers sensor wise sucked. I could never find a setting that worked. It either waited way too long or went way too fast.
Wynn
41
92
Seattle, WA
The rain sensing wipers are awful. Sometimes they won't even trigger until the windshield is completely obscured. Sometimes they kick into high gear with a slight drizzle of rain. Totally unreliable.
PGeer
168
79
Port Townsend, Wa
Seattle area driver here as well (e.g. lots of experience with rain.) Have had all the same problems, but it's no worse than my BMW X5. Almost identical behavior. I use the single push of the button on the end of the stalk quite a bit in light rain. Seems to work more reliably when raining harder.
LovelyCarrot
43
44
Seattle
Yes, verrrry slow to ramp up the wipers even on second sensitivity. I find myself manually triggering it all the time if not on constant wipe. The problem (in my unscientific experience) seems to be that it just takes a very long time to notice the rain level. Almost as though the "rain amount" calculation is using too long of a time window. It does eventually seem to get there, but not before it's difficult to see.
Also a Seattle driver, West Seattle. Hi PGeer :)
Kaush24
New Member
Dec 31, 2016
4
2
Houston
Agree x1000. Just got my MX on friday and me and wife were saying the same thing. I was starting to wonder if they don't work yet in AP2 cars until the next update lol.
aesculus
Still Trying to Figure This All Out
May 31, 2015
4,301
2,460
Northern California
This actually worked for me and was 1000x better than the first setting, which I THOUGHT would have been the more sensitive one.
My windshield was treated with Opticoat and not sure if that makes it streak less or not, but it does not seem to be as bad as many reports I have seen posted on the wipers.
vandacca
ReActive Member
Oct 13, 2014
3,371
2,202
Hamilton
I wish that one of the two manual settings had an intermittent wipe ability. Maybe a software setting to allow for a delay between wipes. I don't find either of the 2 automatic settings work well enough (or consistently enough).
