Driving in snow Hi, everyone. First post here. Will be reserving a Tesla this coming weekend most likely. I live in the Chicago area. Does anyone have sense regarding who the Model S will perform in snow? Is there any direct data or data from the Roaster? Thanks
Tesla did cold weather testing on the Model S this winter. Unfortunately, they did not release any details so what you see in the video is all the information there is. The Roadster is quite a different vehicle (lighter, different battery placement) so it doesn't really have any bearing on how the Model S will handle. With vehicle stability control, traction control and the weight of the battery being even on both axles, the winter ability should be quite good (probably better than many 4x4 vehicles) if proper tires are installed. The main concern is that Tesla chose to equip the Model S with 19" and 21" wheels rather than more sensible 15" or 16" wheels. The 19" tires should perform satisfactorily if proper tires are chosen but had they chosen 15" or 16" wheels the Model S would eat up almost every other vehicle out there. The 21" will be quite poor in winter conditions, so don't get those.
Check this thread for videos of a Roadster driving in the snow (with a comparison to a Subaru): My Roadster in the snow -Shark2k
Our Roadster performed very well over two winters (Minnesota). While there are a lot of difference between the Roadster and the Model S, one thing I expect will be the same is: The traction control is the best I have ever experienced. It is simply phenomenal! Most of the time I would not even be aware it had engaged unless I noticed the TC light on the dash. These guys are Masters of software, which is exactly what traction control is I guess
With an electric drivetrain, the ability to quickly and precisely adjust torque is the key. That said, you do need great control software to take advantage of it. By all claims, the end result in the Roadster has been superb, no reason to think it will be any less on the Model S.
Ahh, snow. Remember what it looks like almost. It did ice over here during the Super Bowl so I did drive my Roadster on a small patch of ice before it melted. Not sure if that counts. I agree with everyone above. I don't see why the Model S would be any different and likely better with its traction control. Tires have a lot to do with it so if you can switch to winter tires during the winter (19" rims) then you should be fine. Welcome as well.
A few months ago I got caught in a blizzard in my Roadster. It handled the conditions very well. As others have mentioned the traction control is amazingly good. I'm sure the Model S will do as well or better.
I live with a lot of snow and have no concerns. 21 inch rims for 4 months and 19 inches with Nokian (canola oil) winter tires for 8 months.
I think you might be a little misinformed Jerry. There are a number of similarities to the Roadster that shed light on how the S will do in snow. Electric drive combined with good sensors and software will beat a similar ICE vehicle hands down. Quick response time, ability to turn wheels extremely slow, continuously variable torque based on available traction independent of speed, no jerky motion to initiate slip (such as transmission shifting) are all qualities that are shared with the Roadster and contribute to great winter handling. Having said that, I think the Roadster will perform better in some cases because it has a higher percentage of its weight over the drive wheels. And in some instances the S will perform better because the suspension will not be as stiff. You'll notice this advantage on uneven ground. Larger tires actually help with winter traction. It's only a problem if you are restricted to very low profile tires which might be the case. But really that's a body problem, not a wheel size problem. I agree with your other comments in this paragraph. I'm looking forward to the adjustable air suspension to raise the Model S when it gets deep. That would have prevented me from plowing snow a couple times in the Roadster last winter!
Okay, that sounds reasonable. I guess we need to define larger. That was my fault for being imprecise. Larger overall diameter tires with the same tread width will perform better because the angle between the contact patch and the free radius is smaller. This helps keep the tire from digging in if the snow is soft and allows the tire to conform to the road surface if the snow is hard. If the tread width is wider but the tire is the same diameter, forward and braking traction will be reduced because there are fewer traction pieces (blocks and sipes) on the ground lined up one after another (like cleats on a tracked vehicle) and the tire will tend to hop and slide over irregularities rather than conform to them. Me too.
I am interested in hearing about real world experiences with the Model S in cold weather, and snow. Now that we are in December, someone must have encountered some inclement weather. We've had a bit of snow in Ontario, Canada, but no Model S deliveries yet. David
There was a Model S here in Ottawa the other day. The side streets here are icy. He wasn't having any trouble.
Sorry, can't help: Record Report Statement as of 12:41 PM CST on December 02, 2012 ...Record high minimum temperature tied at Dallas Fort Worth... A record high minimum temperature of 64 degrees was tied at Dallas Fort Worth yesterday. This record was previously set in 1933 and 1982. Record Report Statement as of 4:50 PM CST on December 01, 2012 ...Record high temperature set at Waco... The high temperature today at Waco Regional Airport was 83 degrees. This broke the old record high for December 1st of 81 degrees which was set in 1970.
No snow accumulation here yet. Just melting variety so far. Very warm today in the mid fifties. I am waiting impatiently to see how my over powered electric car drives in the snow.
RWD Model S Winter Performance Reports I know that it has been well established that the Roadster with its TC plus a good set of tires does an admirable job climbing slippery roads. I assume that the Model S would perform as well if not better in these conditions. Now that winter is setting in I thought this would be the ideal time to start collecting Model S owner reports/videos of how the the car performs on slippery climbs of driveways and mountains. Please include which tires you are using in your report. Thanks.
No snow/ice reports yet, but I can confirm that with 30-35 deg F ambient (-1 to +1 deg C), I have had no problems with the 21" performance wheels on my model S on wet roads. Traction control has kicked in but I feel comfortable with it even though I can feel tires spin very rarely.
Have had a test drive In Oslo. -8*C, fresh snow, slippery conditions and 19" wheels. Not sure About the tires as its their demo car, but its not Nokian Hakkapelliita, I rememver that much. Personally i think the Traction control is awesome! I tried a zero - 60km/h kickdown going uphill ( started In the middle). It went absolutely fine! No drama! Just a slow(er), easy, smooth acceleration. Car didn't seem nervous at all. Had a few 0-60 runs aswell on average snow covered roads, performs superior. On normal driving you will notice that it is a rear wheel drive vehicle, and you certainly do take notice its a beast on batterymunchies- yet i feel as comfortable In it as In my Saab! _____ Tapatalkin' from iTalatut.
