I totally agree with mknox. I've done 304 km (190 miles) at -20C and in a nasty snowstorm, with the heat on. And still had a safe reserve range when I arrived.
I've done a couple of trips in the Roadster in winter conditions, and you can't use the cabin heat at all. After a couple of hours the seat heater just doesn't cut it, you're pretty chilled out! Yet in the Model S I can do even longer trips in total comfort. Despite the cabin being much larger than the Roadster's, it takes a fraction as much energy to heat.
Model S is supposed to have a heat pump, for heating and cooling. I suspect it uses the drive train/battery pack as a reservoir because once things are warmed up the cabin heat power consumption drops dramatically. Plus you can set it to "Range Mode" to limit the consumption.
On one trip last winter I tried driving in similar conditions with the heater on (in Range mode) and off. The variations in power consumption due to road elevation changes were much larger than the additional power draw. I came to the conclusion there was no point turning off the cabin heat unless you were really falling short on range.
