Winter Driving Experiences
Nov 6, 2013
174
19
South Bend, IN
- - - Updated - - -
Took delivery in December 2013 and with new tires, and sensible driving I was very impressed with the Model S during one of the worst winters on record in Philadelphia. One year later (and 30,000 miles) I am surprised at how often the traction control has to come on and how the car slides in today's storm with 3-4 inches of snow. I'mlooking at either snow tires, or even studded tires (overkill, I know) and just swap out the rear wheels each winter. I drive my Model S everywhere as evidenced by 30,000 miles in a year. But, in normal conditions the current tires are fine.
Any snow tire (studded or otherwise) needs to be used as a set of four to be safe. This is because if you use two dissimilar types of tires on your vehicle, you'll have a vehicle that has a "split" personality. One end of the vehicle won't react and perform the same as the other in the dry, wet, slush and snow conditions you'll encounter before the end of winter. Especially in emergency situations, you'll find that your vehicle will probably understeer in one condition and oversteer in another. It is preferable to keep your vehicles handling as consistently as possible by "matching" all four tires. Our customers who have matched their tires tell us they're glad they made the extra investment in four winter tires (and wheels) so they can accelerate, brake, handle and better control their vehicle through winter's challenges.
jerry33
Mar 8, 2012
19,516
21,709
Texas
100% correct. Always use four snow tires. In the most extreme cases, the car won't be drivable on dry roads--the better the winter tire is for winter, the more likely this will happen. Winter tires are made to be very flexible so that they will conform to irregular surfaces and give the best traction.
vwtodd
39
29
Cazenovia, NY
Since I do not own a MS or X (yet), I'd be curious to know how fast you can go on the highest air suspension setting? Can it be used at full-height to drive at 45mph over a couple of inches of snow on the road? Living in Upstate NY, this is a very common condition.
Thanks.
Footbag
527
152
Edmonton, Canada
Thanks.
@vwtodd: It lowers from Very High to High at 22mph/35km/h.
paco3791
TMC OG
Nov 10, 2006
366
7
Antioch, IL
Thanks.
As someone who was originally looking at the air suspension for this very reason I have to say this has been a complete none issue. Even last year when I was on, admittedly new, all seasons in a very bad Chicago winter I had exactly 0 issues even in deep snow with my spring suspension car. The car, and especially the traction control, is just fantastic in the white stuff.
mknox
10,103
1,866
Toronto, ON
I found it useful in snow one time, and as I recall, the incident occurred with a loaner car, not mine. The snow plow left a small bank at the end of my drive and I was in a hurry so I just drove over it. Well, the car got hung up on it and was stuck. I just raised it to very high and was on my way!
Cottonwood
Roadster#433, Model S#S37
Feb 27, 2009
5,088
166
Colorado
Today we had 6 inches of heavy, wet snow in Pagosa; 0.6 inch water content. This made for some interesting driving down and up my unplowed driveway. The last mile is about 500' vertical with some pitches at 16%. BTW, I call my place "Hole in the Wall."
Going down was interesting because it is the first time that I have started a drive with no regen limit, but had a limit appear on the way down. I think it was because the battery bottom was dragging the wet snow and the snow was cooling the battery faster than the regen and heater could warm it.
I did a little video on the way back home and up the driveway. The P85D with Nokian Hakka R2's is just amazing in winter driving conditions!
dsm363
Roadster + Sig Model S
May 17, 2009
18,278
151
Nevada
How about today...
- - - Updated - - -
Took delivery in December 2013 and with new tires, and sensible driving I was very impressed with the Model S during one of the worst winters on record in Philadelphia. One year later (and 30,000 miles) I am surprised at how often the traction control has to come on and how the car slides in today's storm with 3-4 inches of snow. I'm looking at either snow tires, or even studded tires (overkill, I know) and just swap out the rear wheels each winter. I drive my Model S everywhere as evidenced by 30,000 miles in a year. But, in normal conditions the current tires are fine. Sounds like Nokian WR G3 are preferred tires for winter.
You never want to just replace the rear tires with winter tires. Rather all four tires should be the same.
Sorry, Doc and Jerry already addressed this.
evp
Nerd
Nov 28, 2014
706
880
Arvada, CO
I found out exactly what the ground clearance of my Model S is this morning....
rdrcrmatt
607
31
Milwaukee
The Pirelli P7's are absolute hunks of crap. I got stuck not even 10 feet out of our driveway today.
I've been stuck going up a very slight incline leaving a parking lot in compacted snow, not even 2 inches deep.
Cottonwood
Feb 27, 2009
5,088
166
Colorado
I had mine on "Very High" this morning and my driveway looks the same. Should have a nice clean battery pack though!
As I said earlier, after driving two miles in such conditions, I think rubbing in snow does suck heat out of the battery. I had no regen limits when I left the garage, and the regen limit was below 30 kW by the time I hit the highway, two miles later. Mine were probably close to worst case conditions with a very wet, heavy snow.
scott2613
121
39
Wisconsin
In the very same conditions the Blizzack LM32's are working very well on our P85+.
mknox
10,103
1,866
Toronto, ON
I'll bet it does! My driveway is only about two car lengths long (and I was too lazy to shovel this morning), so less of an impact for me :wink:
jerry33
Mar 8, 2012
19,516
21,709
Texas
First ice test on the WR-g3 tires today. Someone conveniently watered one of the streets I commute on and it froze--on an uphill grade. I didn't notice anything while accelerating, but the vehicle behind me went for a nice spin.
Mayhemm
Model S P85+ "Lola"
Nov 9, 2012
1,966
32
Saskatchewan, Canada
I thought the regen limits in cold weather were due to the battery being too cold, not too hot. How would smearing a cold battery with snow speed up regen limitation removal?
