Forty Creek
I got the HPWC as well, but more than just for aesthetics (although I must admit it looks cool):
- I plan on an 100A installation at some point... while the 50A circuit I currently have is plenty for overnight charging... there are cases where a "fast turnaround" or decision for spontaneous trip have come up, and the near-60MPH charge rate would be preferable over the under-30MPH rate
- I don't consider the UMC "permanent installation" device. As a matter of fact the "M" in "UMC" stands for "mobile". I understand leaving it plugged in most of the the time, but I'm not sure that time, flex, weight, etc... won't take it's toll on the plug-head/adapter combo.
-The HPWC has a cable hanger and "plug hook" in addition to the above-mentioned slightly longer cable.
- I want a charging cable in the car at all times. That means that if I want a permanent UMC for the garage, I'm already at $650. Spending the difference for the HPWC for the above reasons isn't that much of an additional expense in the overall scheme.
I have the HPWC for all of the reasons you list. One caution, I've found the "plug hook" to be rather useless. It does not hold the head unit securely and so I just leave it dangling from the coil of wire.
