Winter tires and wheels for Model Y Performance
SBinMT
New Member
Aug 20, 2021
3
2
Montana, USA
Noob here. I have to be honest, I don't understand much about tire sizing so not sure how to really ask this question.
I live in Montana and plan on a set of studless winter tires/wheels for my '21 MYP (picked up just at the end of last quarter). No reason to stick with the 21" wheels so I figured I'd just order something with more sidewall and a bit narrower for snow season. I'm looking for suggestions for studless snow/ice tires and a set of decent looking wheels to put them on. I'm thinking a 19" wheel, but just don't understand the sizing and loading requirements and get a bit overwhelmed when looking online. If I order a set of 19" Gemini wheels, will they fit over the performance calipers? Any other recommendations for wheels?
If I do go with 19" 3rd party wheels, what do I do about sidewall diameter and width of tires?
My local shop that does my wife's tires and my former Jeep tires is a Point S (Interwest Tire) but we just had a Les Schwab open up in the area as well.
Thanks in advance.
jcanoe
3,792
3,856
Maryland
The 19" Gemini wheels will fit the Performance Model Y. It will be easier, simpler if you stick with the OE tire size for the 19" Gemini wheels - 255/45R-19 even you you decide to purchase different 19" wheels.. The 19" Gemini wheel size is 19" X 9.5". More detailed wheel specifications for the Tesla Model Y can be found here: The Tesla Model Y Wheel Guide
Tire Rack has winter wheel and tire packages for the Model Y. You will need a set of 4 Tire Pressure Monitor System (TPMS) sensors specifically made for the 2021 Tesla Model 3, Model Y. If the TPMS sensors are not in stock then you can contact your Tesla Service Center to order a set of the TPMS sensors. This means that you will have to have the TPMS installed in the new wheels, tires mounted and balanced locally as Tire Rack can't mount the tires without the TPMS sensors.
Tesla specifies Extra Load (XL) tires for the Model Y so any studless winter tires should be XL tires. In addition there is a load index number value. This is specified by Tesla as 104 (for the 19" Gemini wheels) but 101 for the 20" Induction Wheels. The load index of the 275/35R-21 tires used on the rear of the Performance Model Y is 103, the front tires are 255/35R-21 and have load index of 98.
The speed rating of the OE performance summer tires is W (168 MPH) but for winter tires you will find tires with a speed rating of T (118 MPH ), H (130 MPH) or V (149).
Let Tire Rack or your local tire shop guide you in the selection of the proper load index for the Performance Model Y with the wheels you select.
https://www.tirerack.com/tires/tiretech/techpage.jsp?gclid=EAIaIQobChMI2uH0qOK28wIVhZ6zCh05Gwa2EAAYASAAEgIN6vD_BwE&techid=35&ef_id=EAIaIQobChMI2uH0qOK28wIVhZ6zCh05Gwa2EAAYASAAEgIN6vD_BwE:G:s&s_kwcid=AL!3756!3!354820920362!e!!g!!tire speed ratings&gclsrc=aw.ds
Reactions: gigawhat?
TwelveVoltMan
He'll make sparks fly round your head
May 14, 2021
160
197
Raleigh, NC
I purchased some barely used 19" Gemini wheels with TPMS locally and had some 255/45/R19 Sottozero 3s mounted to them. That was as cheap or cheaper than other options I found. If you want a simple package that looks like Tesla OEM wheels and comes to you ready to go, I would look here:
Montucky
Blue/Black MYP w/ Tow; OD: 10/02; EDD 11/25-12/04
Oct 3, 2021
64
80
Montana
Thanks in advance.
Hey man - I'm also in MT (Bozeman) and just went through this same exercise. I ended up ordering Fast Replika R241 wheels in 19"x9.5" +45 offset and some 255/45/19 Nokian Hakka R3's. Like others have said, the Gemini's will work, but they're hard to find (I tried). Ultimately, the aftermarket wheels were the best play. As far as weight ratings, that's why I went with the 19" x 9.5" as they had a higher load rating than the 19" x 8.5" that a lof of people go with. For tires, XL load rating is what you want.
I'll be psyched to see you around! My Blue MYP is scheduled for delivery in late November / Early December.
Reactions: minnesnowta
MyTmase
New Member
Oct 25, 2021
4
2
80550
I'm looking into a set for the MYLR I'm picking up in a week...shopping around and Les Schwab's site says these will work, but not sure...they're 18 x 8 (vs. the 8.5 width some go to)...and offset is +40. Will they still work? (Not sure what rubber to match them up with, yet...trying to get my hands on a wheel first)
Apathy
81
41
New York
I have a MYP coming in the next two months and copied Montucky and have ordered the same 19x9.5 R241 Replica wheels (currently backordered about 4 weeks [hopefully]) and the same Hakka R3 XL as well in 255/45/19. They have an SUV version of the tire, but it is impossible to find right now, and the only advantage is an aramid side wall which gives it some extra durability supposedly on the side, but who knows, could just be a gimmick.
The Hakkapellita R3 or Veredstein Wintrac or Michelin Xice3 or Blizzak WS80/WS90 or Sottozero 3 are gonna be the tires you wanna look at for high performance winter studless tire.
Good luck in your search. Had to call 5 different tire places to get what I was looking for.
As stated above, you will need to get the TPMS from Tesla, but good luck with that. You'll need to get them from Tesla and you might have to wait until you get the car in hand. Or you could try walking into your local Tesla dealership and buying that way.
Reactions: Montucky
Steel28
225
335
Toronto
Hakka SUV saved my Replika rim last night. Got too close to the curb.
