Jerry, What say you? I got the impression from this thread that the Hakka R's seem to be the most highly recommended. Is the R speed rating a safety issue?
Only if you go over the speed limit of the tires--and bear in mind that's a sustained speed limit. Winter tires almost always have lower speed limits than the equivalent summer tires.
Here's how it works:
1. The speed limit on the tires is based on the maximum load at the maximum pressure. Reduce the load and/or increase the pressure and slightly higher speeds can be used. There are formulas for this, but basically you lower the load and/or increase the pressure a lot and get a small gain in speed (and reduce tire life as well).
3. If you need snow tires in the area where you live, you aren't going to be going faster than R speeds anyway. (If you are please post when and where so that we can avoid the area
4. If you don't exceed the posted speed limit, you'll never have a problem with an R rated tire.
5. The manufacturer can't put on tires with a lower speed limit because some fool will run them in the summer at the car's maximum speed and then sue the manufacturer.
6. I wouldn't have any hesitation in putting them on my Model S.
Note that other than winter tires, I always purchase H rated or better. The reason is that H rated tires are made to tighter tolerances than R rated tires so there is less chance of vibration or odd wear. In addition, H rated tires have more material in the bead and tread area so they are more robust. It's the deeper and softer tread compound of real winter tires that lowers the speed rating.
