Wiper fluid not coming out
Discussion in 'Model X' started by Socalcommuter, Feb 19, 2017.
Tags:
  1. Socalcommuter
    Socalcommuter Member
    Los Angeles
    2 Month old car and today I tried using the wiper fluid (never used before). Pressed the button multiple times and nothing comes out. Wipers go but not fluid. I also don't have any indicator that it is low. I will take it in for service but any thoughts?
  2. Terthen
    Terthen Member
    San Diego
    Make sure to press it past the first click. One press just moves wipers, the deeper press past the first click gets the fluid out. I also thought mine was broken and asked to get it serviced until they showed me that!
  3. Socalcommuter
    Los Angeles
    Thank you! I will try that again tomorrow.
  4. Chrisizzle
    Chrisizzle Member
    Toronto, Ontario, canada
    Also note, the fluid does not squirt in a stream from the hood or wipers.
    All winter, I saw my right wiper distributing washer fluid but the driver's side was ambiguous. We had our first warm day here in Toronto, Canada and I now see that the driver's side somehow evenly distributes fluid along the length of the wiper (I think). I need to formally look at it but it's kinda like a waterfall along the rubber blade.
    It's a pretty snazzy system if that's how it works but not so great in freezing conditions.
  5. NikeWings
    NikeWings Active Member
    This ^^^ it tricks many new owners but should solve your problem.
  6. FarmerDave
    FarmerDave Supporting Member
    Martinsburg, PA
    From the Owner's Manual: "Press partially for a single wipe, without any washer fluid. Press fully for both wipe and wash."
    RTFM
  7. Socalcommuter
    Los Angeles
    Thank you it works as described in the manual. I read that sucker but I must of overlooked it. It is very subtle as @Chrisizzle mentioned. It was raining today so hard to see. Thank you everyone.
  8. Trev Page
    Trev Page Member
    Aurora, Ontario, Canada
    I just took my X in for some minor service and Tesla Canada has a solution to improve wiper fluid flow. Coupler on the left replaces the older white check valve. Larger bore offers 20% more flow & recent firmware update also starts flow earlier in the stroke. Technician did the swap for me before I even knew it and explained to me a couple of months ago on my first service visit that they were working on a fix to the low flow problem. Guess it’s in place now and they’re doing it to every X that comes in. He said it was for Canada but no harm in asking if they can do it for anyone who asks for it... YMMV
  9. X P100DL
    X P100DL New Member
    Roseville
    Tesla probably restricted the washer fluid flow on purpose because the reservoir is very small on the model X. I can’t see the size, but hardly takes anything to fill it when it’s empty.
