Wiper Motor
Discussion in 'Model S: Interior & Exterior' started by SabrToothSqrl, Sep 30, 2016.
  1. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    So, my 2013 has been in the shop... a lot...
    Went to use my wipers, which, have actually never worked all that well... skips, misses, stuck, etc. I've tried multiple blades from the most expensive I can find, to the cheapest, all with the same results.
    Goes in next week... I'm hoping for a new wiper motor.
    Does anyone know of any changes to it, since the 'early' cars?
    thanks.
  2. Max*
    Max* Charging
    NoVa
    Don't worry, 8.0 will further break it!
  3. Max*
    Max* Charging
    NoVa
    In all seriousness, that's not a wiper blade issue, something is seriously wrong, and in a downpour, this could be catastrophic.
  4. SabrToothSqrl
    PA
    coming soon: wipers with firmware!
  5. SabrToothSqrl
    PA
    well, now they have completely stopped moving, only some vibration and a slight smell remain.
    guess it's time to break out the string and manually move them on a $100k car!
  6. ArtInCT
    ArtInCT Always Learning
    Southern Connecticut
    Ok, this is not good. A friend's S had the same problem... his was caused by the "other" driver, ahem, bringing the S to the car wash.
    The Other Driver did not turn off rain sensing wipers on the wiper stalk. The Wipers turned on during the wash cycle and the wiper motor was FUBAR'ed as a result, due to the wipers being caught under heavy wet flails, etc. The end result was wipers that malfuctioned similar to your symptoms, with the AR-15 automatic rifle sound as the gears skipped.
    I am not saying that is what caused yours to go bad.... but it is really important to note.
