Wiper wobbles
NickF
97
84
Maine
Anyone else experience the wobble as shown in this video? The bottom of the driver wiper wobbles under certain wetness conditions.
Reactions: MS16
David.85D
1,346
1,117
I bought the Bosch icon blades as they are supposed to be better than the stock Bosch blades. But, I don't have that in writing... For all I know, the difference may just be new vs old.
Snerruc
944
1,314
Palm Bay
Replace the 28 in blade with a 26 in blade that should solve the problem. Amazon has them. No meaningful change in swept area.
MS16
330
330
Calif
Yes, mine wobble under most conditions and has since new. The SC said "engineering is aware of the issue" and didn't do anything. I've since asked them for an update and they said there was no update or anything they could do about it.
Maybe you'll have better luck with your SC.
jdw
683
1,300
Montreal, Canada
Happens to everyone as far as I know. Bosch Icon blades really help. In my case I had good results thoroughly cleaning and polishing the windshield and then using RainX. Others have had issues using anything like RainX on the windshield … I think the key is really cleaning and polishing before you apply anything.
AWDtsla
4,262
3,952
NE
It's not RainX. It's a design and part problem:
The reason is improper tolerances on the wiper bracket. If they are slightly loose (which they are) they will wobble until the keep making the bracket even larger, and wobbling even more, and repeat. My solution was simply to use a small C clamp to press the metal side of the bracket until there was a solid connection to the wiper side of the bracket. No more wobble. For now.
  • Disagree
Reactions: KArnold and jdw
AWDtsla
4,262
3,952
NE
Would love to see a picture. You leave it there all of the time? Is the problem on both sides?
Thank you!
C-clamp is only to bend the metal bracket down to a tight fit in a controlled way. It does not stay on the wiper.
edit - and the problem is more with the driver side since the wiper arm is so long (more torque). I left the passenger side alone, because even when loose it doesn't really chatter.
Reactions: KArnold
AWDtsla
4,262
3,952
NE
I think my pet theory has been confirmed. Too much torque required to wipe with a 28" wiper. Tightening the bracket doesn't help for long because the extra force loosens it back up.
1. Tesla has reduced the size of the wiper for 2018 to 26" from 28"! So Tesla has finally caught on and is doing something about this. I bet for 6 years they just had a engineer shove the longest blade possible in there and never wiped outside of their test booth. http://www.piaa.com/Shared/applications/2018-PIAA-Wiper-App-Guide-Master.pdf
2. I put a 18" blade on my driver side just see what it would do. Nice smooth wipes! No degradation over time. But of course it looks silly.
I ordered a 24" blade as a compromise. Should not impede vision at all, since the top/bottom 2" of the stock wiper are pretty much a waste. Hopefully it's not too big.
buttershrimp
Click my signature to Go Mad Max Mode
Jun 17, 2017
2,709
6,201
ATX
Yes I get chatter with Bosch, I bought some Tricos and they were fantastic but service center replaced them upon yearly service, so chatter is back. Trico is pretty awesome I think
