HankLloydRight
No Roads
You can get these wired, or RF wireless transmitter pairs... Mine is wired but if you buy wireless it means you don't have to run a wire through the firewall .
The front camera kit doesn't require going through the firewall. It routes very cleanly up through/under the frunk trim panels and the weather stripping by the driver's door. On my cars, you can't even see it. Installing the front camera (at least on pre-facelift cars) is much easier than the original instructions may indicate. Getting power from the OBDII port is very simple (no splicing required). Running the camera cables from the front is also pretty easy. The only "complicated" part is running a single wire either to the pax footwell or the rear hatch to tap into the reverse signal lead.
