Yes.. giddy with anticipation about this. Would totally eliminate the need for parking sensors--for me, at least.
Another question. Does anyone know if there are any special characteristics of LVDS cable? I'm going to have to run cable from the front camera location to the connector location SUPRKAR identified. I think twisted pair will do the trick but if there's any special needs it would be good to know before I cut the stock cable open.
artsci, I recommend caution here. As I understand it, LVDS is a high-throughput data transmission standard requiring impedance matched twisted pair, here used for HD video. Here it is one-way using 2 of the wires and the pair is probably 100 ohm impedance and therefore the receiver would match. If you just cut into it and install a standard mechanical switch, I'm guessing there is no way it would work; the switch would not be impedance matched and both camera signals would just reflect off the impedance mismatch at the switch and never reach the receiver. Think about cutting an Ethernet cat5 cable and trying to install an inline mechanical switch---doesn't work. Instead you typically need an impedance matched switch which do exist but are active (just like a network switch in my analogy).
It doesn't hurt to try your simple way and see how much signal gets through, but I would not cut into existing cable because you run the risk of ruining its impedance matching even if you resoldered it later (again, try the same with Ethernet cable and you will find you need to replace the entire cable---I would like you to avoid needing to do this on your new car). Instead you could rig up a Y adapter that uses the impedance-matched connectors, so you can always reconnect the stock wiring at the connector junction if you find it in the kick panel.
Here is a source/info page for LVDS.
LVDS & CML Home — LVDS, CML, M-LVDS, Bus LVDS, Signal Conditioning, and Switching/Muxing Solutions - TI.com
A good starting point is "LVDS Owner's Manual."
I am not an expert.
It looks like this IC implements a quick 2 x 2 LVDS matrix switcher. We'd need a couple of electronics engineers to chime in with the rest of the circuitry to build a quick schematic of a functional circuit, but realistically, it doesn't need to be very expensive.
I would suggest using proper connectors everywhere (finding the same connector Tesla is using) to make it a plug-and-play solution. I would imagine the whole circuit (with an enclosure and associated connectors) could be built for less than $100... but then there's the cost of the "front" camera and labor to get it installed for those who can't/wouldn't do it themselves.
Do we have an EE who's willing to design the circuit for this? Also, I've been searching everywhere for these Amphenol connectors and just can't find them.
Also, here's the promised photo of the inside of the camera. There doesn't appear to be a switch to change the screen orientation, but then again I didn't take it fully apart to see the other side of the small circuit board.
Rick,
Have you checked Digikey for the connectors? Do you have any details/marking/part numbers on the connector that could help narrow the search? All I've done in this search is selected amphenol connector and four conductors, but maybe you can help narrow the search with a couple other parameters?
I did some googling of LVDS to bring myself up-to-speed on this. There is a good wikipedia entry on LVDS. I would assume that Tesla has used point-to-point flavor of LVDS since they probably did not consider adding anything else to the current bus. It is interesting that there is a multipoint LVDS option, but I doubt Tesla would have implemented this since it appears to be more complicated and therefore most expensive.
So in looking at this I think zax123's suggestion of some type of LVDS switcher/mux is the way to go. Ideally this would be a plug and play board with 2 input amphenol connectors and 1 output amphenol connector. There may have to be some sort of 12V DC to DC converter required to generate a 5V or 3.3V supply because I don't think the onboard supply for the camera is going to be able to drive the switcher/mux board. The switcher/mux board would then have to drive the power for the 2 cameras (which should be reasonable).
Then the next issue will be getting a proper cable from the switcher/mux board out to the nosecone. This has to be a proper cable. It seems that if Tesla has the cable from the dash to the rear camera, another of these same cables can be used to connect the front camera.
The last thing is how to switch from one camera to the other. Ideally there would be something on the touch screen to swap back and forth. But I don't know if we'll ever get a hardware output from the touchscreen for this. So we'll just have to see what people come up with for this.
Anybody have experience building LVDS systems?
