Wireless Phone Charger for Tesla Model S
Discussion in 'Model S' started by Ritu_o0o, Jan 30, 2020.
  1. OVB1
    OVB1 Member
    Los Angeles
    Installed yesterday, took 5 min but broke one of those little things that keep the wire in place. Oops. Be careful folks.
  2. mbhforum
    mbhforum Active Member
    Long Island, NY
    I’ve had two MS’s and have broken all 8 of them. They are poorly made and any sort of pressure will break them. If you try to run multiple wires or a thick wire through them, it’s game over.
  3. alexdav
    alexdav Supporting Member
    Long Beach, CA
    Same. I installed the wireless charger on Wednesday and broke one of the clips in the X. The wire is quite thick for the wireless charger. I couldn't fit it plus the USB for the SSD that I had sitting below, so now the rubber mat is sticking up a bit. I need to find a right angle USB A to USB C short cable at some point, which would help some.
  4. Kush Plank
    Kush Plank Member
    United States
    I’m waiting for Jeda who makes the m3 to finally make one for the S/X
  5. vraev
    vraev Member
    Mississauga
    I just installed mine today as well.
    It cost me $190 CDN incl taxes. Crazy for a wireless charger, but I wanted the clean look. I think the majority of the cost went towards making the box. This is some apple quality packaging. lol
    Again, the tabs on mine were also bent..super hard to install it without breaking them off. the cable is thicker
    The negative is that my PIXEL 4XL doesn't seem to be getting a sufficient charge from the charger. It says charging slowly. I need to test it with another phone to see if it is a pixel issue or the charger is putting too low of a charge. Not to mention, I do have an MCU 1 and that could be limiting some speed as well.
  6. TSLA Pilot
    TSLA Pilot Active Member
    United States
    IIRC, the two USB power ports have different outputs.
    Try the other USB port, and also doublecheck the instructions on which one you're supposed to use.
    Thx for the writeup.
  7. mbhforum
    Long Island, NY
    #27 mbhforum, Jul 18, 2020
    I am going to take 3M reversible tape and tape the mat down and wires down. It's the only way it will remain flat with thicker cables. I am getting my wireless charger this week. I also have a thick USB extension cable running through there that goes to a lightning cable that i have that comes out of the center console in case we need to charge wired. I don't want to have to store wires anywhere.
  8. mbhforum
    Long Island, NY
    Here is the Lightning cable I have hanging out when I need a wired connection.
  9. r1200gs4ok
    r1200gs4ok Active Member
    Irvine California
    thats the one I have and it works great.....I have a micro, lighting and wireless charging capability......
  10. mbhforum
    Long Island, NY
    I assume your talking about the tray? I got the ICEBeamer Carbon Fiber one from Amazon. The wireless charging tray never worked great which is why I bought the Tesla OEM.
  11. r1200gs4ok
    Irvine California
    yes....I did not like the Tesla one because it won't it my phone with a battery case.....the tray wireless works great....and it give me the option of having the capability of being able to plug a music usb in the center outlet if I want
  12. posey_mvp
    posey_mvp Member
    mine is coming in soon.. does anyone know how fast it charges an iPhone 11 Pro? Is it better to connect the usb to 12v port using an adapter for faster charging?
  13. mbhforum
    Long Island, NY
    Yes. It also depends on whether you have an MCU1 (limited to 5w charging) vs MCU2 (7.5w “fast charging”).
  14. posey_mvp
    posey_mvp Member
    I have MCU2. Does it mean I can just use regular USB port?
  15. alexdav
    Long Beach, CA
    Just a heads up with the iPhone 11 Pro, I had the leather case on mine and it damaged the bottom of the side of the case from pushing it into the wireless charger. I have a Max, so maybe the regular one won't be impacted, but I switched to the silicone case since I had it handy.
    As far as fast charging, how can one tell besides measuring the approximate gains in percentage over time? I'm not aware of an indicator otherwise.
  16. bob_p
    bob_p Active Member
    Instead of the Tesla wireless charger, we purchased a dual wireless charger ($85) from the Green Mission Store.
    It supports charging two phones at the same time (requires two USB connections, which we hook to a dual-charger adapter plugged into the 12V port), and provides enough room for each phone to easily hold our Galaxy phones inside their cases.
  17. mbhforum
    Long Island, NY
    #37 mbhforum, Jul 21, 2020
    I got my wireless charger, and yes the packaging is very impressive, Apple like.
    One negative is, I cannot close the lid anymore because the top of the wireless charger hits my USB Drive/SD Card for the TeslaCam, as well as my other USB cable. I will need to get some dongle extensions so these things can lie flat and be hidden. However, for the USB/SD Drive card, I tried a USB extension and my MCU didn't recognize it.
  18. treowx
    treowx Member
    Katy Texas
    Just as a heads up so someone like me doesn’t make the same mistake. This will not fit a drop in console pre-2016. Will only work with a premium console or I would assume newer X or S. I tried in mine it will fit but you cannot close the lid and it doesn’t lock in place.
  19. FatherTo1
    FatherTo1 Member
    How long does it take to wirelessly charge an iPhone or Note 8/9/10/10+ with only 7.5W? For $125, I expected at least 15W but I guess it's limited by the USB ports. What if we plugged it into a USB adapter in the 12V socket? Would the Tesla wireless charger still only deliver 7.5W?
    The wireless charger is a cleaner look but it seems like I'd be paying a whole lot more for less functionality and much slower charging than a wired solution.
  20. Pluturi
    Pluturi Member
    Upstate NY
    I tried using the 12V, but I believe the charger is limited to 7.5W so it doesn’t use the extra current typically available. Unfortunately you are paying more for a slower solution that is more elegant than using a wire.
