Wireless Phone Charger for Tesla Model S
Discussion in 'Model S' started by Ritu_o0o, Jan 30, 2020.
  1. SD Diver
    SD Diver Member
    San Diego
    Hmm... 11 Pro Max with the Apple leather case. No issue.
  2. FatherTo1
    FatherTo1 Member
    That's the other dilemma for me. Wife has an iPhone 11Max, but I prefer Galaxy Note 10 Plus. Tesla wireless charger will only accommodate one phone at a time, right? I would still need to rely on a cord for at least one other phone.
    Part of me is still tempted to get the OEM wireless charger anyways but that 7W charge rate is a dealbreaker when Samsung offers a 45W car charger for the Note 10+. It would be like Tesla ChargeGate for my phone.
  3. nomis_nehc
    nomis_nehc Member
    Rancho Cucamonga
    Can you post some pictures? I looked at their product page, and while the product itself sounds good, the way the trays look, it looks rather rough and unfinished to me. Wonder how well it would function if it was wrapped or maybe spray painted to have a smoother surface?
  4. OVB1
    OVB1 Member
    Los Angeles
    Noticed odd behavior with the new wireless pad when I have my phone charging the car warns me it cannot find my key when my key is near the phone which is where I used to always keep it even with phone charging connected to usb
  5. opticron
    opticron New Member
    Huntsville, AL
    I so just recently installed the OEM Tesla Qi charger in my Model S and it just doesn't charge my Pixel 3 well. The phone says that it's charging, but only barely gains charge and sometimes it loses charge. I have MCU1, so that's obviously part of the problem, but even 5W charging should charge it slowly. I have a bumper case on it, so there's no additional material between the phone and the charger, just 1-2mm of air. I need to do some more testing with placement height and removal of the case, but it's not a good start.
  6. kdday
    kdday Active Member
    AZ
    I think you’re limited by the abysmal power provided by the USB port (coming from the MCU actually). Mcu2 is the same.
    Probably smart to buy a higher Amp 12v cigarette adapter and plug wireless charger into that
  7. vraev
    vraev Member
    Mississauga
    I have a pixel 4 XL and I found that after my MCU2 upgrade, the wireless charger does somewhat slowly charge the phone. Prior it was basically useless. I did once leave the phone on there for an hour and it did go from 60% to 100%. However, this was while I was just sitting in the car without driving it. I don't know if other power usage impacts the current flow to the charger.
  8. opticron
    opticron New Member
    Huntsville, AL
    Yeah, I have one already for wired charging and the cord is just long enough to get to it. With MCU USB power and the case on, it just constantly cycles charging/not charging. I did a little testing with and without the case and that's not the problem. It seems that to hit the sweet spot on the Tesla OEM Qi charger, my phone needs to be 1/4" to 1/2" up from the bottom of the slot.
  9. opticron
    opticron New Member
    Huntsville, AL
    Install accubattery to see what the charge current is and try changing the vertical position in the slot. I had to move mine up to hit the coils right and I'm going to cut a few riser blocks to shove down in to the slot.
  10. vraev
    vraev Member
    Mississauga
    Sure. I'll give it a shot.
  11. Nuclear Fusion
    Nuclear Fusion Active Member
    Outside a bubble
    Need a cheap equivalent from Taptes or Jeda
  12. 68882
    68882 Member
    Victoria BC
    Same, any suggestion to fix this? You would think the Tesla engineers doing the charging pad would confirm RF interference doesn’t nick the key fob
    Tho....
