Wireless rear view camera that could be used on the 1.5 cars?
Discussion in 'Roadster' started by ecarfan, Jun 22, 2016.
  1. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    #1 ecarfan, Jun 22, 2016
    This product looks like it could be ideal for the Roadster: a license plate frame with a camera mounted in it, the frame contains batteries to power the camera and to connect your phone over a locally generated wifi network which displays the camera image, plus the frame has a small solar cell to recharge the batteries (read that in a news story about the product, it's not on the company website, see These Three Apple Engineers Want To Put A Backup Camera With Computer Vision On Your Car).
    Company website is here: Pearl - No New Car Required
    Claimed to be shipping in September. Let's see if they can execute.
    One concern I have: it appears there is something that you plug into the car's OBD port to make it work. I already have an OVMS plugged into my Roadster which I do not want to go without. The Pearl Auto website gives no specifics about the product so it doesn't describe that.
    Pearl Automation’s license plate cover puts a car backup camera on your phone
    Apple Alums Dream Up a $500 Backup Camera For Any Car
  2. MileHighMotoring
    Parker, CO
  3. ecarfan
    San Mateo, CA
    Yes it is expensive, but it's wireless so you don't have to provide power to the camera or run a line from the camera to the dash display.
  4. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    How is it powered???
  5. jeremyz
    jeremyz Member
    I would guess magic. Or maybe a piezoelectric charger or magnet moving back and forth through a coil that is using the car's motion to charge a battery.
  6. Habious
    Habious Member
    Springfield, VA
    The OVMS module plugs into the Roadster's DIAGNOSTIC port (which is located in the passenger footwell), not the OBD-II port (which is required to be located in the driver's footwell...within a certain distance of the steering wheel).
  7. MileHighMotoring
    Parker, CO
  8. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    Not a lot of information, but I guess they are getting at least the following from the OBDII port:
    a) Gear selected (reverse, forward, park, etc)
    b) Speed (the camera shuts off once you’re rolling forward at 10 mph)
    c) Power for the dongle
    The Roadster OBDII wont provide (a) or (b), so this probably won't work.
    From a point of view of co-existing with OVMS, there won't be a problem. They use different ports (roadster uses DIAG port, this uses OBDII port).
    • Informative x 2
  9. ecarfan
    San Mateo, CA
    Mark, thanks for clarifying, my ignorance about modern car electronics knows no limits.
    If the Roadster OBD II port won't provide your a) or b) I think the product may still work, the camera image could just be on all the time which in fact would be my preference! I leave my S rear view camera image on all the time at the top of the center display. That is what I have always wanted in my 1.5.
  10. ecarfan
    San Mateo, CA
    Keep in mind that this product is 2 cameras for stereo vision with image processing to determine distance from objects and alert the driver of the car is close. Pretty cool. If it works well.
  11. Rolf68
    Rolf68 Member
    France
    Hello markwj
    I didn't know that the Roadster indeed had a ODB-II installed. I once wanted to buy a HUD to cast the speed on the windshield, as I find it hard to read on the display, but I abandonned the idea once I discovered that those products mainly plugs in a ODB-II and I didn't find any reference to it in the manual.
    You say there's one in the Roadster, but if it doesn't provide gear nor speed, then what's the purpose of this stuff??
    Best regards
  12. Habious
    Habious Member
    Springfield, VA
    I bought a OBD-II HUD display from Amazon once. Plugged it in...didn't work (it got power but, no usable data from the car.) I ended up going with a GPS-based HUD unit...works really well in the Roadster.
    So, yeah, there is an OBD-II port for sure on the Roadster (they're required on all passenger cars by the Clean Air Act of 1996) but from a user perspective, it isn't of much use.
  13. markwj
    Hong Kong
    Good question. From what I can see, there is very little of interest on that port. About the only uses of it are (a) for the TPMS reset tool to talk to the TPMS controller box, and (b) to get 12V power for accessories. There is certainly no standard OBDII controller on it, and it doesn't respond to any of the normal OBDII standard commands.
    Perhaps there is legislation to say that all cars have to have an OBDII port, but doesn't specify they have to provide any data on that port if they don't need to provide emissions data (which is the original purpose of the port in the first place)?
    • Informative x 2
  14. Habious
    Habious Member
    Springfield, VA
    The first generation of On-Board Diagnostic requirements, called OBD I, was developed by the California Air Resources Board (ARB) and implemented in 1988. As technology and the desire to expand On-Board Diagnostic capability increased, a second-generation of On-Board Diagnostics requirements was developed. This second version of On-Board Diagnostic capabilities is called "OBD II". The Clean Air Act Amendments of 1990 mandated that, beginning with the 1996 model year, all light-duty vehicle and trucks made available for sale outside of the state of California must also be equipped with OBDII.
    The OBD II system monitors virtually every component that can affect the emission performance of the vehicle to ensure that the vehicle remains as clean as possible over its entire life, and assists repair technicians in diagnosing and fixing problems with the computerized engine controls. If a problem is detected, the OBD II system illuminates a warning lamp on the vehicle instrument panel to alert the driver. This warning lamp typically contains the phrase Check Engine or Service Engine Soon. The system will also store important information about the detected malfunction so that a repair technician can accurately find and fix the problem.
    Source: Link
  15. Rolf68
    Rolf68 Member
    France
    #15 Rolf68, Jun 24, 2016
    Ok, so if I understand correctly, its presence is required by law but doesn't do anything useable. Too bad, as I suppose it wouldn't have been too much pain to make it functionnal for HUD / other third party goodies. Thanks for the answer :)
    P.S. I also considered buying a GPS based HUD, but those are quite expensive for what they do.
  16. Rolf68
    Rolf68 Member
    France
    Yep, sound slike a requirement. I wonder if there's such a thing in the european Roadsters, as we don't have the TPMS installed. Maybe it simply isn't implemented in our cars... Thanks for the answer :)
  17. Rolf68
    Rolf68 Member
    France
    Very informative, thanks :)
  18. Habious
    Habious Member
    Springfield, VA
    This is the one I bought...
    Amazon.com : Generic WY-A1 Universal GPS Speedometer with Over Speed Warning : Car Electronics
    $56.00...but a 3-5 week shipping time so, I hope you're not in a hurry for it!
    It plugs into the 12V accessory outlet, but I hardwired it (via an add-a-circuit fuse tap) into the fuse panel . Very clean installation. I've also found that a length of clear tubing from Home Depot works great for tucking the wire down at the bottom of the windshield. No adhesives, and can be removed in 1.5 seconds.
  19. Rolf68
    Rolf68 Member
    France
    Hello Habious
    Thanks for the link. This one seems to be quite affordable and without the unnecessary "Bling-Bling" other models are delivered with. I'll give it a try, I'm not in a hurry it's just a nice to have feature in the car ;)
    Best regards
  20. Cattledog
    Cattledog Active Member
    San Antonio, TX
    OK Germany, we'll bite. Because the next generation of Autopilot will be much more than the equivalent of airline autopilot, let's leapfrog the issue and come up with a name that sidesteps the issues Germany (and others) have with 'autopilot'. Let's find a name that could mean less than autopilot now but much more later, without needing to change the name again.
    Ideas?
    Tesla Drive
    Hyperdrive
    Driveshare
    Setitandforgetit
    Arewethereyet
    These are boring, what about some others, this is a creative group!
