there is no such thing as a range increase unless tesla admitted they have locked a portion of the battery.
I don't completely agree with this. I see where you are coming from, but there could be other optimizations done that cause the overall system to use less power. Shutting down unneeded processors, running fans at lower speeds after a bit more real-world experience, changing the power curve or other behaviors of the motors and so on. You'd think most of these things would have been done before first release, but HW3(as an example) certainly wasn't there for first-release.
the efficiency gain from optimization would be marginally at best. Auxillary power draw already has neglible impact as it is.
Simply remapping the typical range doesnt do anything but change the scale.
The Model 3 short range now goes 262 miles
What do you mean since no one has acquired one to look at yet and who is "we" and how was this confirmed?....We confirmed that the new M3 do NOT have the Model Y heat pump.....
Also, I charge to 78% for daily use, before the update, it was 248miles, now it's 256miles est. range. So there are some improvement already.
The Model 3 short range now goes 262 miles. My range was 250 miles when I bought it in March 2020. I am told the Chinese short range model 3 will go 290 miles. I am told I have to trade in my car to get any longer range. WHY can't I just buy a new battery? This makes NO SENSE to me??
I took delivery of a M3 DM LR three weeks ago. When I purchased it, the 0-60 time as 4.4s. After updating to 2020.40.4 a few nights ago, it now says 4.2s and there is a noticeable improvement in acceleration.
No, there isn't.
Humans are notoriously bad at judging this stuff- but the only improvement was on paper- Tesla updated their website, finally, to reflect the 5% power bump that happened last year-
LR AWD went from 4.4 to 4.2 (though it's actually 3.9 if you measure the same way they do the P)
LR AWD with boost went from 3.9 to 3.7 (though it's actually 3.5 if you measure the same way as P)
And P went from 3.2 to 3.1
But those cars were already that quick.
No additional power has been added, and folks with calibrated measuring devices have tested since the website was changed, and no difference in measured times.
I guess I missed this before.
This would be interesting because it would probably imply a 3% capacity increase. Which is somewhat in keeping with what others have speculated (@TimothyHW3 for example). It also aligns with the 580/560 ratio for the WLTP cycle.
Presumably this would mean that it has the newer higher capacity Panasonic batteries.
It's unlikely to be efficiency improvements, because Tesla doesn't typically increase displayed range with efficiency improvements.
So if this information is confirmed (would be nice to see a picture of the software update info for the update that changed the range), it mostly seems to point to a larger capacity.
You could also take a picture of the Energy -> Consumption screen and capture the three numbers at high SoC: Numerical displayed remaining range, projected range, and recent efficiency. All with three significant digits. (It's super important to capture all THREE numbers - the number next to the battery, efficiency, and projected range.)
That would help confirm the charge constant is still about 241Wh/rmi. If that remains the same and your 100% displayed range next to the battery icon (not projected range) is higher than the original 322 for 2020 Model 3, it means a capacity unlock. There would be no ambiguity.
thats different due to torque mapping from avoiding torque ripple. You cant compare this with just adding 40km of range.
You are correct, this turned out to be rumor. I apologize.What do you mean since no one has acquired one to look at yet and who is "we" and how was this confirmed?
