Wood Dash Wraps! Post them here!
Discussion in 'Model 3: Interior & Exterior' started by warrior15r, Aug 28, 2018.
  1. warrior15r
    warrior15r Member
    Anaheim
    Hi Everyone,
    I'm looking for ideas on what to wrap my wood dash with. Since there are so many threads, I figure it would be nice to have a single thread for everyone to post all their wood dashboard wraps! I would like to see what Model 3 owners have done to theirs!
  2. HelloJohnny
    HelloJohnny Member
    Fontana, California
    Thanks for starting this thread! Great idea btw.
    I have mine wrapped in 1080 3M White Carbon Fiber on a Pearl White Model 3.
    White_Carbon_Fiber_Dash_Wrap_1.jpg White_Carbon_Fiber_Dash_Wrap_2.jpg White_Carbon_Fiber_Dash_Wrap_3.jpg
    • Like x 4
    • Love x 3
  3. Jimmy 1
    Jimmy 1 Member
    Tallahassee, FL
    • Like x 8
  4. jrc0yne
    jrc0yne Member
    Jacksonville, FL
    HelloJohnny - The white dash looks awesome. I was thinking about doing this, thanks for posting! Are you happy with how it looks in person?
  5. mekberg
    mekberg Member
    Madison, Wisconsin
  6. forkee
    forkee Member
    Southern California
  7. HelloJohnny
    HelloJohnny Member
    Fontana, California
    Thanks! It looks great in person, originally I wanted a matte white but the shop that did the install said the grains/grooves of the wood would show through the vinyl so I'm happy I went with White Carbon Fiber. From a distance, it actually looks matte white.
    No issues, it has a matte finish so no reflection issues from sun and windshield. I had a local shop do the install. They used 1080 3M vinyl for the wrap and use a heat gun to wrap the edges on the sides near the door since they were the more difficult to wrap. Hope this helps!
  8. netjack
    netjack Member
    jersey city
    any black/dark wood versions?
  9. Jimmy 1
    Jimmy 1 Member
    Tallahassee, FL
    3M Di-Noc has some great black wood wraps, that would be awesome.
  10. R1Fast
    R1Fast P3D Blue/White
    Seattle
    I've been trying to find a 5 foot piece of di-noc or other cast formable wood grain vinyl with little luck. Most sellers only have 4 ft or 25 ft rolls and the price gap is enormous. A 2 piece install is an option but to be believable it shouldn't have any seams or folds.
    Would like to see how you guys are wrapping the corners. All of the wrap kits I've seen are a simple fold and crease, but this looks cheesy and kills the realism IMO. Since the dash corner is in plain sight I've been trying to find a good way to stretch over the back and front 3 edge corner but haven't had good luck using sample pieces.
    Biggest problem is the back corner where it meets the plastic. There just isn't a lot of room to pull the vinyl through and down cleanly and it keeps bunching up or tearing (takes a lot of stretch to get a clean 3 sided corner). The practical option is to fold and crease but even the best attempts don't look great.
    Exaggerated example at the other end of the scale.
  11. TM3KT
    TM3KT Member
    Fairfield, CA
    Wrapped my dashboard in the black brushed finish to compliment the matching center console and door trim.
  12. davidalai
    davidalai Member
    Los Angeles
    Where did you get the wrap from? I'm planning on doing a black brushed look.
  13. TM3KT
    TM3KT Member
    Fairfield, CA
    I bought the roll from Amazon (3m 1080 vinyl). A 12" x 60" roll was more than enough to DIY cover the wood trim and center console.
  14. R1Fast
    Seattle
    Can you share the direct link to the roll you bought? I've tried 2 of these (3m brushed black and vvivid aluminum) and they both had the grain running vertical.
    Really want horizontal but both sellers said I'd have to buy a 5x5 roll for that.
  15. TM3KT
    TM3KT Member
    Fairfield, CA
    Unfortunately, what the sellers are telling you is 100% correct. If you want the grain to go horizontal then you'll have to buy the 60" x 60" roll. My 12" x 60" roll off Amazon (probably the same one you bought) is enough to wrap the wood trim however the grain is vertical as seen in my photos above.
    I know @Kenriko is working on developing a pre-cut kit for the wood trim (and will most likely include the same brushed black option that he offers for his center console and door trim kit) but am not sure which direction the grain will go.
  16. R1Fast
    Seattle
    Thanks!
    It looks like the grain is running the long way on the roll unless I'm blind or that isn't 1 piece. The ones I've tried have it running the short way.
  17. TM3KT
    TM3KT Member
    Fairfield, CA
    It is 1 piece and is running vertically across the trim (running it the short way). I've attached a photo of it in the shade so that it may be easier to see.
  18. R1Fast
    Seattle
    Thanks, wow that's kinda crazy. The first picture looks horizontal til I squint and get really close to the monitor. Might be time for an eye exam. :)
  19. rlb4
    rlb4 Member
    Northern NJ
    Anyone have pics of the black matrix on both the console and wood dash? trying to decide between the black matrix, black brushed metal, and carbon fiber. The carbon fiber pics I have seen seem a little too glossy. The black matrix gives a carbon fiber look but is more matte.
  20. R1Fast
    Seattle
    #20 R1Fast, Oct 29, 2018
    Ended up going with a Di-Noc architectural wrap (grey ash).
    Took a bit more patience due to thickness but cut pretty easily with heat. Also I struggled with the 3 sided corners til I realized the plastic end caps are removable. Removing those made it wayyy easier and also made the results nearly seamless on the back corners.
