Eikrokei
Perhaps a subject for a different thread, but wouldn't you expect AWD with 4 motors to have a significant effect on range due to additional draw from the pack?
They will probably use 2 motors, not 4. Easiest solution is probably to add a smaller motor to the rear of the frunk. Remember that the motors will only draw more when accelerating, not when cruising, also the use of two motors allows them to use different gearing without the use of a gearbox, this will allow a small increase in efficiency. In summary, if you actually use the available acceleration the range will go down, if you don't floor it the range will probably be as good, or maybe even a little better.
