Working PEM to Mars? What a waste!!
Discussion in 'Roadster' started by ModelS, Feb 5, 2018.
Tags:
  1. ModelS
    ModelS Member
    Fremont
    • Funny x 2
  2. coolVariable
    coolVariable Member
    Los Angeles
    I assume the car was gutted. No fluids, no batteries, no real tires, probably a lot of other stuff removed. Not a chance in hell they are sending batteries that will likely explode in space.
    Probably just something of equal weight in there ...
  3. dpeilow
    dpeilow Moderator
    Winchester, UK
    Called dibs on that last year.
  4. gregd
    gregd Active Member
    CM98
    The official paperwork does list the car as "modified", so I presume such steps were taken. It would be a shame if an otherwise-perfect launch would get messed up by an unruly payload.
  5. coolVariable
    coolVariable Member
    Los Angeles
    Agreed. The tires or battery exploding may cause sufficient thrust to move the payload of target - not what they would want (and cheaper too to gut it)
  6. Oricle
    Oricle Member
  7. gregd
    gregd Active Member
    CM98
    Also in the view from inside the Roadster, you can see the VDS is missing from below the climate control knobs. And the rear view mirror is missing, not that Starman would really need it.
