brucet999
What about the following user?
ICE. Drives away leaving a gasoline soaked connector. Someone comes along and plugs into their Model S, starting a charge session. Isn't that a fire risk?
Not in the least.
First, that connector could not touch liquid gasoline from inside the filler door, so it couldn't become soaked.
Second, even if it did have liquid gasoline on it, the highly volatile (that doesn't mean explosive, folks, just fast evaporating) light fractions would evaporate off in a couple of minutes, leaving an oily residue like paint thinner which is difficult even to ignite with a match in an open bucket at temperatures under 100ºF.
Third, the fumes from any such hypothetically drenched connector, taken still dripping from the truck to the charging port, would be unable to form an explosive mixture in air because there would not be enough air space surrounding it in the charge port to dilute the vapors to below 7.6% of the air volume needed for ignition.
Fourth, the charge port connections are tight enough that there would be no arcing possible and no electricity flows until a good connection is made.
