Would 21x10 rims fit on front and back of an S?
Discussion in 'Model S' started by viper2ko, Aug 20, 2018.
  1. viper2ko
    viper2ko Member
    Would 21x10 rims fit on the front and back of an S? Found a deal on a non-staggered aftermarket setup but not really sure if it would fit.
  2. Atlantan
    Atlantan Car Obsessed
    Berkeley Lake
    Not sure about the front, will fit in the rear.
  3. P85_DA
    P85_DA Supporting Member
    It will rub on front I wouldn’t do
  4. Doanster1
    Doanster1 Member
    Oregon
    Agreed. They probably wouldn’t even be able to be mounted much less rub. Depending on the offset, you’re either going to hit the upper control arm or if you went with a high enough offset to avoid that, you won’t have enough stud length to properly tighten the lug nuts down, which would necessitate getting longer studs.
    What are the exact specs of the fronts you’re considering?
