M Monkeyboo Member Mar 25, 2018 17 2 Toronto Nov 8, 2020 #1 Nov 8, 2020 #1 Hi can anyone let me know if these wheels/ tires specs fit on a model Y LR ? Size 245/35/R20 front 275/30/R20 rear 20*9.5 offset 45 front 20*10 offset 41 rear Center 60.1mm Thank you
E E_R_N Member Jun 16, 2020 179 183 Vancouver Nov 9, 2020 #2 Nov 9, 2020 #2 I think the center is too small. Pretty sure you need 64.1. Plus you didn’t mention bolt pattern.
M Monkeyboo Member Mar 25, 2018 17 2 Toronto Nov 9, 2020 #3 Nov 9, 2020 #3 E_R_N said: I think the center is too small. Pretty sure you need 64.1. Plus you didn’t mention bolt pattern. Click to expand... Oops sorry the bolt pattern is 5 x 114.3mm. I guess the centre bore is too small then thank you for confirming ...
