⚡️ELECTROMAN⚡️
Village Idiot
Do these have similar handling without the expense of long term mileage?I will be going with Michelin Primacys from now on.
53,000 miles with tread to spare at 3/32” - Michelin Primacy OEMs S85.
versus:
19,000 miles so far, worn to 4/32” - Goodyear Eagle Touring OEMs S90D.
When these wear out at maybe 25,000 miles, if I’m lucky, the car will get Michelin Primacys.
Not happy about the poorer, regressed quality in the newer car, between the much poorer longevity of the tires, the accelerated wear of the seats, and the shortcomings of AP2 relative to AP1.
Not a bit.
Me too. Just took my car in for it's first year service with 12,500 miles on it. I rotated my 19" tires at about 6500 miles. They called and said My tires were well below the wear limit with 2mm on the front and 3mm on the rear, and that they were wearing evenly, so probably not an alignment issue. They said they could replace them for $1,045. They're nuts if they think I'm going to spend a $1,000 a year on tires. I feel like I'm being punked. Is this for real?Goodyear Eagle Touring OEMs as well
these are the 2 i am looking at for 75d.....which is the better of the 2. ??Uniontown has pretty crappy roads, my brother in law lives there.. I would switch to something more durable like:
Pirelli Cinturato P7 All Season Plus for 2016 Tesla Model S 75D
or
Continental ExtremeContact DWS 06 for 2016 Tesla Model S 75D
Because of the inside tread of the tire wearing, what does this signify? Alignment issue or some manufacturing defect like panel gaps? Rear tires seem to wear evenly.
There should be a tire mileage warranty available but not through Tesla. Go to Americas Tire and they will handle the warranty if one is available.Me too. Just took my car in for it's first year service with 12,500 miles on it. I rotated my 19" tires at about 6500 miles. They called and said My tires were well below the wear limit with 2mm on the front and 3mm on the rear, and that they were wearing evenly, so probably not an alignment issue. They said they could replace them for $1,045. They're nuts if they think I'm going to spend a $1,000 a year on tires. I feel like I'm being punked. Is this for real?
Play loud rap and hip hopDo you have any thoughts on what kind of practical sound dampening steps a person could take? without ripping door trim off and all of that?
By the way, I used a tractor tire repair kit on my performance foam tire, which meant I got to stab a bigger hole into the tire and shove rubber gunk inside of it.... and it's been doing great.... it's not quiet anymore though because I also followed it up with a little sealant fix a flat spray.... It's kind of like having a slightly stuffy eardrum on one side, but I'm going to get a few more thousand miles on these tires! Definitely made me appreciate the foam tires though... it definitely makes a difference with certain frequencies.
Best Post EVER
I need to think of a bet for the shrimpster for which, after losing, one must listen to hopelessly slow and complex classical music for 2 hours a day for a solid month. Either that or opera. Yeah, that's it. Shawshank style.
... even allows shipments from tire rack.
What on Earth am I doing wrong? I drive around 25,000 miles a year. I have done two "annual" service appointments so far this year, and both times I had to replace my tires. Is this normal? I purchased the good year 19s both times. Should I be buying a different tire or is there no way to avoid this in a 75d? I am not a heavy foot and rarely speed. My commute averages 45mph and that's what I stay at. Any advice?
Wouldn't an alignment done by Tesla Service take care of that issue?Is it the rear tires that wear the most or all four? If it’s the former you may need adjustable camber links. There’s a long thread on the topic. Until I installed the adjustable links and set the rear camber to -1 I would get about 10k out of a set of rear tires. Now it’s 3-4 times that.
The type of tire matters but not as much as the alignment, especially the rear camber.
The rear camber can't be adjusted in a stock Tesla -- hence the market for the adjustable links. Tesla will give a reading for the rear camber, but I would question whether that is actually a measurement or just a number filled in by the computer, since they can't change it and don't want to show it is out of spec when they can't do anything about it.Wouldn't an alignment done by Tesla Service take care of that issue?
