Wow, we need to find another way to heat EVs
JLuszczek
7
3
Lancaster
I
I just know you’re kidding. Isn’t the idea of an EV to get away from fossil fuel? Duh!
Someone in the know would have to run the numbers, but it's not all that obvious that burning hydrocarbons for heat locally is worse than converting them to electricity remotely, charging the battery and then heating an electric coil with that electricity. The first scenario is nearly 100% efficient, the second scenario is maybe 70% efficient. If your electricity is less than 30% from renewable sources you are not adding more CO2 to the atmosphere by burning fuel for heat.
Reactions: Phlier
Jack007
189
143
Calgary AB
Huuuuuggggeeeeee impact at "cruising at 77". Its not linear power usage its more like exponential. "cruising at 60" is much much much much (much much much much) more efficient, from a power usage, not counting heat. It will take you longer to get there going 60 than 77 so not sure how that math works out, but people really discount the effect speed has on range, and it is HUUUUUGGGGGGGEEEEEEEEEEEEEEEEEEE
So this is based off gas vehicles but will give you the idea.
55 mpg this is where mileage is calculated at.
60 mpg is 3 percent less efficient
65 mpg is 8 percent less efficient
70 mpg is something like 17? can't remember
80 mpg I DO REMEMBER is 28% less efficient
people gripe about a penny at the pump then drive 80.
ALSO WINTER IS 6% DENSER AIR cold air affects mileage too people.
If it's cold and i'm driving out of supercharger territory,
i'm doing back roads and goin 50 max,
saves me a lot of time at the L2 chargers.
Oct 18, 2019
9
0
Vermont, USA
As pointed out in this thread, there are things that can be done to increase range in colder temperatures (speed being the biggest). There is a definite difference (decrease) in range in colder temperatures. Pre-heating the cabin helps a bunch as it gets both the cabin and the battery up to a comfortable temperature inside and the battery more efficient and less of a heat draw. Once driving, we are a bit more bundled up, and I have several wool blankets in the car for passengers. I also use the heated seats and steering wheel, all of which makes for a more comfortable ride. If you plan it out in advance, it is just a bit more planning, and a bit longer charging, but all worth it. My biggest issue is that when you get to less than 20%, the defroster starts becomming ineffective, so I try and plan the trip so I dont get that low on battery.
1.21GW
731
1,167
Michigan
I hope you mean Miles per Hour, not Miles per Gallon. My mind was not comprehending how 80mpg is 28% less efficient than 55mpg.
Reactions: GWord
cmghoughton
29
9
Lake George
This might be were the Porsche has the slight advantage, although I haven't really read to much about it so I might be talking out my rear on this one. I thought the Porsche had like a variable gear, like a high/low to allow it to hit that max top speed. I wonder is something like that could be geared up more for efficiency since realistically 80mph is kind of the norm on the open highway.
Also the cabin heat, I drive 75mph to work every day about 50 miles on the highway and I've tried to keep the cabin heat off. It's like 20 degrees out and after a few minutes you can feel the cold start to creep in at highway speeds. The heated seats help but I didn't spend all this money to now buy a heated jacket too.
I wish the range would just auto adjust because of the weather, no more guessing game because of the range loss.
jjrandorin
Nov 28, 2018
7,261
8,040
Riverside Co. CA
I wish the range would just auto adjust because of the weather, no more guessing game because of the range loss.[/QUOTE]
The energy graph does adjust to your current consumption, so the car tells you what its guess is on your range based on your current consumption already.
cmghoughton
29
9
Lake George
Oh I know, it would just be nice if it was up front vs digging down a little bit. I hate it when I'm driving home and I've gone like 10 miles and 20 have dissipated from the range. Started with my Model 3 in the winter so I can't wait to see how it handle in the summer.
DigAdrenaline
353
332
Canada
SR+ 90 mile trip. Temps below freezing
First road trip - ok, mini road trip. I was expecting some range loss but was surprised by almost 50%. 77 of the 90 miles was on the highway so not sure of the impact of cruising at 77.
Way out - day: 27 degrees, sun shining
Charged to 230 miles, little over 90%. Got there with 93 miles left, about 37%. Used about 140 of range to go 90 miles.
Way back - night: 22 deg car cooooold
Level 2 charged to 188. Energy graph said I would get home with 11%, actual was 14%, so did not need to spare the heat, radio or speed.
The trip worked as the level two was close and I had 3+ hours before my return. Also had a super charger 20 min away. If I wanted to leave after an hour, not sure I could make that work in the winter time With just the level 2. Will do the trip again in spring and summer, will be interesting to see the differences
Car drove great, fun ride!
but heating is a range killer. More than I expected. I think we might need better solutions or bigger batteries. Can’t wait for battery day.
This is why us Canadians were so happy to have Superchargers across the Trans Canada Highway. (And PetroCans Chademo as backup).
realvvk
261
216
Philadelphia
You think this is bad, try driving a base Nissan Leaf in the winter. 30-40 mile range at moderate speeds on the highway, about 50 miles on suburban roads (50 mph) with the heat on. The range indicator is the biggest issue because it is way too optimistic. You fall below 50% battery and the range starts falling twice as fast as you expect.
I often do a 17 mile drive on Sunday mornings. My Model S will show a very precise range estimate and I feel zero range anxiety no matter the state of charge. Leave home at 50 miles range, arrive with 33. My Leaf will often show something like 50 miles remaining in the beginning of that drive and 12 miles remaining when I arrive. Total BS! Before you ask, I can do this because there is an L2 charger at my destination.
Sybaseguru
10
5
Glossop
Drag is proportional to square of speed, and drag is what sucks your power. Tesla quoted miles work out at 60mph without heating, so speed alone will drop your mileage to 60% of range. Combine with a cold battery inefficiency and add cab and battery heating which can go up to 7kwh and you are probably about right.
TrustThis
New Member
Oct 2, 2019
2
4
Santa Monica
I agree, even w/o the pun ;)
Maybe the efficiency of these will improve enough to make it worth it. I mean the AC is already a heat pump, don't know how much it takes to 'reverse' where it sends the heat
Can heat pumps solve cold-weather range loss for EVs?
Thank you that's a very useful addition to the discussion.
I would be very surprised if Tesla wasn't already working on their own (killer) implementation of a heat pump to improve real world range.
Zcd1
693
793
Chicago area
After 14 months of ownership and 1.5 Midwestern winters, I've settled on 67 degree cabin temp and the seat heater at "1". I'm never cold or even chilly, and this keeps the range impact at a manageable level.
Range in my M3P with 20" wheels is 210-230 miles at 70-75 mph in 20 degree temps.
Reactions: navguy12
TomB985
441
515
Isanti, MN
I
Not everyone bought their car for the same reason you did. Not saying getting away from fossil fuels isn't a worthwhile goal, but that's not why I bought it.
And I would LOVE a gas or diesel-fired cabin heater. They can run for hours on a gallon of gas, and will be a lifesaver taking longer trips in the cold we have up here.
