This look Amazing, but I think with a black T will look better than the white one. Where did you get the steering leather and carbon fiber from?even farther overboard!
Did you take the steering wheel off to do it?Finally done mine, the bottom part is a nightmare .
If you're worried - paint it.My only concern is the the wrap on the airbag might hinder the deployment of it if ever needed. Don’t think something that is intended to blow open should be wrapped but it does look good.
How much did you have to sand it? New to this and trying to figure out if it is feasibleFinally done! Thanks to @TLLMRRJ for letting me hijack slightly his thread. I do have to say if this is your main car and if you decide to wrap or paint it...you’re gonna need at least a day to do. Paint will need multiple coats and some fine grit sanding. If you have an extra bezel it’s sooo much easier and swap out only took 15 mins.
View attachment 513689 View attachment 513690 View attachment 513691 View attachment 513692 View attachment 513693
Just a light sanding. Nothing crazy. Spray light and foot away. Sand. Spray. Sand. Spray. At worst if you mess up.....sand it back down and wrap. The sanding portion is just so everything is even. Kinda like how they wetsand bondo. Use a high grit like 600+ or more. Nothing coarse or abrasive.How much did you have to sand it? New to this and trying to figure out if it is feasible
How long to dry between coats?Just a light sanding. Nothing crazy. Spray light and foot away. Sand. Spray. Sand. Spray. At worst if you mess up.....sand it back down and wrap. The sanding portion is just so everything is even. Kinda like how they wetsand bondo. Use a high grit like 600+ or more. Nothing coarse or abrasive.
Whatever the spray can /paint can saysHow long to dry between coats?
I looked at the one you posted, and i think it was between 30 minutes and 2 hours. Does that sound right?Whatever the spray can /paint can says
Thanks @TLLMRRJ for the idea
received my trim piece today from eBay and ordered the wrap BUT i am gonna spray paint it instead. Too many areas to fold the wrap around. Researched and found Krylon matte white paint/primer so gonna give it a try. Should only take 5 mins to paint. Bonus is that the trim itself stands off the ground so you can actually evenly coat it.
Also for whoever wants my original one I can coat yours and send it to you or send it plain. I bought another trim bc I didn’t want the down time but once this goes in I can paint/send my swapped version.
View attachment 512742 View attachment 512743
Yes I did. Sorry.hi did you ever end up selling your old trim?
Quick question, do you sand the plastic before the first coat or is that not necessary? I will be using krylon fusionJust a light sanding. Nothing crazy. Spray light and foot away. Sand. Spray. Sand. Spray. At worst if you mess up.....sand it back down and wrap. The sanding portion is just so everything is even. Kinda like how they wetsand bondo. Use a high grit like 600+ or more. Nothing coarse or abrasive.
