I’ve started looking at B.A. Designworks subwoofer box.
I thought they were sold out as well?....I'm sitting over here like wow, whats the hold up with the manufacturing process.
Nah, BADesignWorks has stock. They just had a halloween sale, but if you email them and mention TMC forums, you can get a 15% off discount.
They still have a sale going on. Think I may jump on it. Have you bought this system yet? I don't live near there shop its a 3 plus hour drive for me.
I decided to buy a 10" rockford fosgate powered subwoofer box. It fits in the trunk well and provides plenty of bass for my for <$200.
Here's what I installed:
https://www.amazon.com/Rockford-Fos...e=UTF8&qid=1541609062&sr=8-1&keywords=p300-10
Don't get the 12", it doesn't fit in the trunk well.
Would you mind sharing your experience so far? How bad was the install and how did you run the wiring? I'm considering exactly this sub. Thanks!
I'm very interested in one of these and have experience doing my own 12v audio installs. I was researching and someone mentioned quick disconnect cables to remove for track days or luggage space. Does this include the power, ground & remote turn-on wiring? Also, does the stock system have an RCA output or did you have to run a hi/low converter to get power for this?
More details and any photos you have would be appreciated as this seems like the perfect way to add more sound on a budget as compared to some of the fancy pre-packaged alternatives more Tesla owners go with. I'm not looking for fancy, just more sound and something that I can easily remove for when we go on long road trips and want to sleep in the back.
Which brings me to another question; think the sub box will fit in the lower hatch storage area when not in use? That would be ideal for our needs as that's where we keep pillows and the air mattress normally but when we sleep in it we could unplug the sub, drop it down there after we take the bedding out.
ETA: It looks like it does not include a wire kit but some reviews say you can use a 10AWG amp kit which will supply plenty of juice for the amp (dual 10A fuses for a total of 20A max) also has a setting to remotely turn on/off based on audio/voltage presence like home powered subwoofers so no remote turn-on needed. It looks like you attach the power & ground to a harness that plugs into the side along with a separate speaker input harness making for quick removal which is something else I was looking for. The fact that the positive wire is safe when you unplug it to avoid grounding out is a definite bonus for quick detach.
So you actually installed yours down in there. Good to know it fits and maybe that makes more sense than moving it around the way I'm thinking. I'll have to give that some thought.It has a quick disconnect from battery in the form of a plug that the battery + and ground - screw into.
It has no wiring. Buy a minimum 8 gauge wiring kit.
The 10" unit fits in the "well", which you are calling the lower hatch, of the trunk so you don't even see it. The "pockets" on either side of the well allow air to pass through which makes a great bass resonator.
Overall the sound system is decent after you add the subwoofer. My only last complaint is the rear door speakers. They are garbage... need to balance about 20-30% more bass and volume from those rear doors. I do this by moving the speaker balance to just behind the center console in front of the rear seat.
Just another bump to ask a couple new install questions and answer some of my own questions from above after additional research.
First to the OP:
You mentioned having a helper sit in the front driver's seat with the door closed to tune while you adjust back at the box so I was hoping you can share your final settings so that I can get pretty close out of the gate with minor tweaks necessary for tuning afterwards. I assume you tuned with the remote knob set to 50% so you can increase and decrease as necessary from your base setting up or down on the fly? What was your gain set at roughly for a percentage (or clock if min is 7:00 and max is 5:00)? What % did you find to be the best setting for the crossover adjustment? Guessing that one is around 50% somewhere or around 80Hz? Did you leave the Bass Boost at 0 on the box or did you increase that at all? Looks like the max setting is 12dB.
The other settings are just Phase (0 for most applications) input level (hi if tying into speaker wires directly of course) and auto turn-on (which I've read that either DC Offset or audio can be used but the better choice is probably audio for a hi level input) for anyone else interested in installing one of these w/o doing tons of additional research.
I'll numerate to make the response easier (question marks are the ones I'd like your input on)
1) Gain (%?)
2) X-Over (50%?)
3) Bass Boost (0%?)
4) Phase (0)
5) Input Level (Hi)
6) Auto Turn On (Audio)
I have everything on-hand & I'm going to start install here in a couple of hours so if you have enough time to address just 1-3 above that would be ideal to get me going.
Up next to answer some of my own questions for anyone else looking to do this install:
I discovered that other than an amp kit (power wire, ground wire, speaker wire and connectors) you don't need anything else to install this P300-10 (or 12 for that matter) sub/amp combo. No remote turn-on wire and no RCAs. Just tap left & right factory speakers (easiest is the fronts since you'll be working under the front kick panels anyway) and run speaker wire to the rear where the box is, cut the RCAs off of the included harness and attach the front L/R neg/pos wires to that little fella. Run your power and your ground and you're good to go. Looks like there's a convenient spot to ground under the carpet in the rear next to the driver's side wheel arch. Remove bolt, grind off paint and bolt up.
Thanks!
