WTB: One 20" OEM Model 3 Performance Wheel
TrumpetTitan
Model 3 Performance
May 17, 2018
44
17
Baltimore
Looking to purchase a single wheel for use as a full-size spare. Will purchase with/without OEM tire mounted. Cosmetic damage is fine, so long as the wheel is structurally sound and not bent or unbalanced.
Located in Rosedale, MD 21237.
dgcaste
11
11
Why not go for a cheaper spare with the same wheel radius? Only asking since you’re ok with cosmetic damage.
TrumpetTitan
Model 3 Performance
May 17, 2018
44
17
Baltimore
I could, but I want to use the spare as well, so I'm always monitoring it's pressure and so the tread will be the same if I have to swap it in a pinch. I'm used to doing a 5-wheel rotation pattern on older cars. Also if the wheel is damaged when I need the spare, then I'll have the replacement on hand instead of having to wait for a service center to order one.
I'm OK with some curbing on it since I've already curbed two of my wheels :/
