I'm interested in the following Tesla part (not sure if it's the same for X and S, but either will suffice):
ASSY - CAMERA - REAR VIEW 1006773-00-E (or comparable)
Given that the new cameras are only $78, I'm probably going to wind up going with one of those. Sorry, but that price is pretty cheap, especially in comparison to the original price on the older model.Do you still need one of these?
Thanks. I am planning to mount it on the back of my Airstream and use that camera while towing as a rear-view look behind the camper. It'll also help with backing into campsites. I'm probably best getting the new one since it's a bit of a security thing. If it were $600, used made more sense.. but $78 is pretty cheap and I'm ordering cables anyway. I do appreciate the offer quite a bit, though.OK, I wasn't sure what you needed it for. I had one on my front bumper for the camera kit, but whenever it rained A LOT, the camera would go blank... and a day or later it would "dry out" and start working fine again. I think the O-ring was mis-seated when I originally installed it (fixed). Anyway, I found a replacement so I have this one as an extra. If you wanted something just to test with or hack up, I'd sell it to you for $30(shipped).
I am guessing You have the front camera kit is it easy to install. Can I hook up more then one. The reason I would want more then one is because my model s has the 3rd row and I would like to be able to check on the kidsOK, I wasn't sure what you needed it for. I had one on my front bumper for the camera kit, but whenever it rained A LOT, the camera would go blank... and a day or later it would "dry out" and start working fine again. I think the O-ring was mis-seated when I originally installed it (fixed). Anyway, I found a replacement so I have this one as an extra. If you wanted something just to test with or hack up, I'd sell it to you for $30(shipped).
Yeah, if you don't want the front camera, one kit and one extra camera will totally work. Artsci would know better how to hook up the cabling with the rear camera, since he just replaced his and knows that area well. In fact, I think this is such a good idea, that Rick should offer it as an alternative installation option, since a lot of people have gerry-rigged other solutions to watch the kids in the back.
I don't think there would be anything funky with the cabling at all.
The rear camera winds up cabled, as per the instructions.
The unit itself plugs in under the dash, and to the 17" display connector, as per the instructions.
The only change would be instead of running the cable from inside the cabin out to near the license plate, for the front camera, they would run that cable to the wherever they want to shoot the back seat from. The car would still automatically put the reverse camera on the 17" display when reversing. The regular, "front" view would be whomever is in the back seat. The only issue would be where to mount the back seat camera, and how to hide that cable.
At least that's how I see it.
I didn't really mean funky, but I'd do it differently.. I'd mount the control module inside the rear hatch, plug in both cameras into the module back there, and the single feed that goes to the front of the car.. then you don't have to run any cabling for the rear camera to the front of the car.
