WTB-Roadster charge port for my Rav4
Discussion in 'Want to Buy' started by TonyWilliams, Nov 25, 2012.
  1. TonyWilliams
    TonyWilliams Active Member
    San Diego - Tesla powered Rav4 EV
    I would like to use the 70amp Clipper Creek EVSE with Roadster "nozzle" and need the charging port from a Roadster.
    Thanks,
    Tony
  2. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    Interesting idea, and I hope it works...but I'm not sure it's gonna be quite that easy. I think there is some communication that needs to go on and I'm not sure that swapping out the port is going to accommodate that. But perhaps you know what you're doing...I most certainly do not know a lot about this. But clearly one of the major weaknesses of the Rav4EV is the extremely limited charging options and that could open a lot of new opportunities for Rav4 EV owners.
  3. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I charge my Rav 4 EV fine with my clipper Creek TS-70 with a J1772 connector. No issues whatsoever. It is able to use the full 10kw
  4. vfx
    vfx Well-Known Member
    CA CA
    Your service center can sell you one.
  5. TonyWilliams
    I'm hoping somebody converted their Roadster to J1772, and has one sitting around for "cheaper".
  6. vfx
    CA CA
    Jim's conversion retains the Tesla plug behind the J plug so if neccessary it can be accessed through the trunk for Tesla charging.
    I'm waiting for the Model S plug to become available. Maybe it is???
  7. TonyWilliams
    I'm thinking something similar. I can put both ports under the hood (the Tesla 10kW charger is physically there, too) and just crack the hood open to use them.
  8. strider
    strider Active Member
    NE Oklahoma
    Why wouldn't you just convert the Clipper Creek "Roadster" EVSE to J1772? But I would check w/ Tomsax as he converted his Roadster to J1772.
  9. TonyWilliams
    #9 TonyWilliams, Dec 2, 2012
    Here's some information he provided:
    "Here are the part numbers I have, with prices from February, 2011."
    6000523 : $817 (for the 2008 model)
    6003434 : $725 (for the 2010 model)
    6001535 : $1,193 (unsure which model)
    The 2010 has a 7-foot cable with simple lugs at the end. The 2008 has a
    2-foot cable that's terminated in an expensive Amphenol twist-lock connector.
    - - - Updated - - -
    Can somebody identify the correct part from this long list?
    ACA-B Series
  10. vfx
    CA CA
    I should clarify that the charge port doors opens to the working J1772 socket. It's only when you want to use the occasional Tesla plug that the cord comes out the closed trunk lid.
  11. TonyWilliams
    Burnt pin on current Rav4
    Update: My Rav4 was fixed under warranty for a burnt pin on the charging port. I also got a Camry rental for a week, also courtesy of Toyota. Of course, I don't think the Rav4 had anything to do with this, and IR thermometer testing indicates at least one other Blink/Rema handle got quite hot on one pin (opposite to my pin) on a Rav4. Keep in mind, these are only 30 amp Blinks and the Rav4 can take 40 amps.
    Conclusion; a poorly crimped connector on the Blink/Rema charging handle.
    More pics here
    The Blink plug:
  12. hcsharp
    hcsharp Active Member
    Vermont
    You were lucky it was covered under warranty if it was caused by the bad crimp in the Blink/Rema charging connector.
  13. JoshG
    JoshG Member
    I'm not all that technical... do you just want the black flexible connector that goes from the HPC to the roadster, with the twist barrel on the roadster end? Or do you want to buy an entire Tesla/ClipperCreek HPC? May have the latter for sale soon, but don't want to take it apart, would sell the whole thing.
  14. TonyWilliams
    I need the opposite of the black connector; HPC female connector to J1772 male. I have a Clipper Creek charging station.
