X versus S Supercharging...who gets the juice?
Discussion in 'Supercharging & Charging Infrastructure' started by IanMcL, Sep 19, 2019.
  1. IanMcL
    IanMcL Member
    Laverstock
    I was in Bristol yesterday and needed a charge to get home. Both bays at Cribbs Causeway, apparently spare.
    However, on arrival, 5 mins later, a Model X was charging.
    I started to charge my 2016 S in the remaining bay.
    15kw charge out of 130kw!
    I thought it might recalibrate but it did not. I even stopped and restarted the charging, but to no avail.
    That seems totally unbalanced and pointless for the 2nd vehicle.
    2/3 to 1/3 I could understand but 90% to 10% seems faulty and the word supercharger registered invalid!
  2. Ostrichsak
    Ostrichsak Active Member
    Colorado, USA
    This is pretty well-known: First car in paired stalls gets 100% of their charge rate & 2nd car gets whatever is left of combined total.
    Lesson: select your charge bay based on not being paired with an occupied stall if charge rate is important.
  3. IanMcL
    IanMcL Member
    Laverstock
    When there are only 2 bays, that is pretty naff!
  4. Big Earl
    Big Earl bnkwupt
    Springfield, VA
    It starts at 75%/25% but there was evidently a problem with the charger that resulted in lower output.
    Why is this in the Roadster 2020 forum?
  5. MorrisonHiker
    MorrisonHiker S 100D 2021.4.11
    Colorado
    It's also possible the OPs battery already had a high state of charge, limiting the kW the Supercharger would provide.
  6. mociaf9
    mociaf9 Active Member
    Assuming your battery was low enough that the car was capable of accepting a faster charge, then the hardware wasn't fully working properly. The second car to plug in should be getting up to ~30 to 36 kW if the first car is charging with a low battery. Once the first car's rate tapers to below 72 kW, the second car's rate will increase.
  7. IanMcL
    IanMcL Member
    Laverstock
    That is normal elsewhere. I was low. That is why I wondered if the big X was favoured. Sounds like equipment not doing its stuff . Thanks.
