X: What's your 90%?
loganintx
608
465
Austin, TX
Here's a handy spreadsheet that I've made and been using to know the exact distances between all of the SuperChargers that I would encounter on my normal trips.
Tesla SuperCharger Location Distances Calculator
I know the EV Trip Planner and others exist but I like seeing the exact miles between lots of different superchargers and making the decision of how much SOC I'll need and which SCs I should stop at along the way.
loganintx
608
465
Austin, TX
I was watching a Model S video and right at the 11min mark he mentions Standard vs Max charging and refers to Standard as charging to 85%.
Take a listen:
I'm guessing the video is older but interesting as to why they recommend 90% now and 85% then.
VerityZooms
131
104
Chicago, IL
Data from teslalog.com
Image: http://i.imgur.com/tSBbRyS.png
Image: http://i.imgur.com/n9nLOme.png
I know this is a bit off-topic, but … do you have an invite to that site? It looks real, real cool (I'm a quantified-life type, so I've been using Fuelly.com / GasTracker+ for yeaaaaars, and I definitely want to use the equivalent for my Tesla.)
  • Disagree
Reactions: Buckeye2320
loganintx
608
465
Austin, TX
I think you only need this link to get signed up:
TeslaLog - Register
There is a warning about your Tesla password being sent through his site though. Knowing how easily small servers can get hacked, that was enough for me to keep from registering. In the future, if Tesla allows a tokenized authorization then I would use the service.
VerityZooms
131
104
Chicago, IL
TeslaLog - Register
(Simply change your MyTesla password to something temporary, use this to generate an API key, then change your MyTesla password back.
As he makes clear, he doesn't *store* the password you enter on his site, nor does he need to; he *is* using tokenized authentication, there's simply not yet any UI on Tesla's end to generate one, so he has to do it for you.
Even if he's been hacked recently, and that page is compromised, it won't end up with my password; just a revokable API key. ¯\_(ツ)_/¯)
Reactions: X Fan
dwebb66
349
85
Ladera Ranch, CA
If you Change your password, does it invalidate the token?
Reactions: loganintx
goneskiian
2,618
805
Bellevue WA
Highest for the P90D: 232 (LobosPac)
Highest for the P90D: 232 (DJFrustration and djbakasan [something about those DJ's! ;) ])
Highest for the 90D: 239 (vjlvjl and JimVandegriff)
Cheers!
ThosEM
Space Weatherman
Dec 13, 2013
869
308
Annapolis, MD
We do charge to 95% or 100% at times. But one good reason not to charge to 100% is so you'll have regenerative braking when you start out. That goes away completely on a full battery. This is especially true if you live in a high area and go downhill soon after departing.
"Vampire" drain is a real load on the battery to support electronics functions you may take for granted. Most if not all can be switched off in the "energy" settings, but I like to keep the car "always connected" so I can reach it without delays to wake up...
Reactions: Mark Z
scottf200
3,770
3,326
Chicagoland ModelX S603
Cheers!
This may (likely) have been discussed before but it only appears to be a slider and not sure if it "snaps" to 5 increments or just single digit increments? In other words could some people be setting their slider to 89% and others at 92% (i.e. not everyone on 90% exactly).
goneskiian
2,618
805
Bellevue WA
You're all the ones with the X's in your garages. You tell me. :p;)
MarchX
29
28
Arroyo Grande, CA
At 1750 miles I'm at 235 ,but I've moved the charge level around a few times and wonder if there is some small variation in getting it exactly back to the 90% mark.
For the first 6 weeks it was at 237 - 239
Reactions: goneskiian
