X with 21" staggered from Model S
Discussion in 'Model X: Driving Dynamics' started by Laumb, Dec 4, 2016.
  1. Laumb
    Laumb smrtass.
    Lost in Norway
    Hi!
    Does the staggered 21s from Model S work for the X - and have anyone found any tires with the right dimensions and load index to be compatible with an X?
    The X has wider tires, but the difference isn't so large that it'll look weird in my opinion. 265 vs 275 rear and 245 vs 265 front.
    What would be the "perfect" dimension for 21s from S on an X?
  2. 3s-a-charm
    3s-a-charm Active Member
    Calgary, Canada
    The bolt pattern fits but I've been told the wheels will not clear the calipers due to different offsets.
  3. Ender345
    Ender345 Member
    San Francisco, CA, United States
    Trying to find out the same thing - have been told by the dealership that with spacers it will work, but that they don't recommend it because it can cause damage to the car. Can't tell if that's true, or if they just want me to buy new wheels. Also told by an aftermarket wheel shop that they wouldn't recommend it - but they also want to sell me wheels. Hoping someone here can weigh in on the question? I wanted to use 21" Turbine wheels from a MS on my MX - would save me quite a bit of money. Thanks!
  4. Tsportline
    Tsportline Vendor
    Los Angeles, California
    The 21" OEM Turbine will physically clear the Model X brakes since the same brakes are used on the Model S. However, the 21" OEM Turbine might not be load rated for the weight of the Model X (approximately 6800lbs Gross Vehicle Weight Rating).
    Our 20" TST wheels are loadrated at 900 kg per wheel and fit both the Model X and S.
    Our 22" MX Forged collection of wheels are loadrated at 900kg as well.
  5. goneskiian
    goneskiian Active Member
    Bellevue WA
    I find this hard to believe since Elon had 21" wheels on his X at the official release last September. I suppose they could have been custom made or perhaps had spacers on them.
  6. Tsportline
    Tsportline Vendor
    For those who are still curious, we tried it on our own Model X. We still do not recommend it because we still do not know if these wheels will hold the weight of a Model X long-term.
    • Informative x 3
    • Helpful x 2
  7. goneskiian
    Bellevue WA
    Thanks for the confirmation. Strange the load rating isn't printed on them!
    I'm sure the information is somewhere but what is the weight difference between these and the 22's?
    Cheers!
  8. Tsportline
    Tsportline Vendor
    The information is somewhere, but not in a service center and not on the wheel. With many of the nightmares MS owners have had on 21" Turbine wheels, MX owners beware. (To be fair, there's many MS owners with 21" Turbines who have had 0 issues.)
    We weigh a 21x8.5 turbine at approximately 35.4lbs
    We weigh a 22x9.0 turbine at approximately 37.6lbs
  9. Yinn
    Yinn Active Member
    Behind you
    What do the 20" Slipstream's weigh, and what do your 20" TST's weigh?
