Comparison of Stock, Tesla HID, DDMTuning DIY HID headlights
First, thank to augkuo and another owner, we were able to get 3 Roadsters with different headlights together for a good comparison:
- Stock Headlights
- Tesla HID Headlights
- DDMTuning 55-watt HID Headlights rated at 4500K (other color temps available)
Test procedure was:
1) Position a car with its lights pointing at a wall about 43.5' away, and mark the wheel locations with PostIts on the ground.
2) Put Post-Its on the wall to indicate top cut-off line.
3) Put Post-Its on the wall to locate positions at which lumen measurements were taken.
4) Write down measurements on the PostIts.
5) Take a RAW photo of the illuminated wall with a camera locked on manual settings.
6) Position next car in same spot as previous, as close to the ground PostIts as possible given our patience.
7) Repeat 4-5, then repeat 6 & 4-5 for the last car.
8) Process all photos in Photoshop with the exact same processing settings (via "Synchronize" in Camera Raw), get all 3 photos as layers in a single file, align the layers, then crop the file. Toggle each layer's visibility and "Save For Web & Devices" at a reasonable resolution, JPEG at lowest compression.
I suppose we could have gotten more scientific (for instance, we didn't have the camera on a tripod, but just stood at the same mark and aligned the viewfinder's grid on the same element), but to be honest, as soon as we turned on all 3 cars' headlights, there was no question as to the results. Note that the cut-off point for the headlights was different on all 3 cars. We don't know if the higher output lights pointing up higher was coincidental or is a side-effect of the higher output.
Note also that we were only measuring low-beams. I suppose we should have also measured high beam output as well, but there wasn't any beer where we were.
First, the photos:
Stock:
Tesla HID:
DDMTuning 55-watt HID:
One thing you'll note is that the color temperature is different on all 3 lights. If anyone really wants, I can do the processing again with the processing color temperature individually to the output of each headlight. All 3 photos here were processed at 3750K, which is a bit higher than the Tesla HID, but pretty close to that. Stock headlights were probably 3200K and the DDMTuning's were rated at 4500K. Daylight is 6500K, and Audi's LED headlights are supposedly set to 5500K.
Here's the table of lux readings. Looking at the photos, each reading was taken along the lower row of PostIts, from left to right to match the table. I did try moving the meter around at each spot, but the needle hardly budged (this is an ancient analog Sekonic meter, btw), so I don't believe the different cut-off heights really matter. For the Post-It behind the bush I took the readings just in front of the bush. We did not make the effort to find the brightest spot for each headlight, and we didn't create a big grid to catch vertical differences. Refreshments and a warmer evening would be required for that.
Stock | 108 | 140 | 140 | 108 | 129 | 140 | 86 | 65 |
Tesla HID | 172 | 215 | 215 | 205 | 172 | 194 | 140 | 108 |
DDMTuning 55watt HID | 226 | 409 | 409 | 323 | 258 | 409 | 237 | 129 |
You're reading that table right: Tesla's XID is about 60% brighter than stock, but DDMTuning's 55watt XID (4500K) is 200%-300% brighter than stock!
Note that in some states, aftermarket replacement lights are not legal.
