Since I finally decided to ppf the full exterior of my Model 3 (Deep Blue Metallic), I've been seriously considering the matte/satin finish of XPEL Stealth or STEK Dynomatt. Would anyone care to comment on the maintenance of any of these ? I've had the clear/glossy ppf applied to my last 9 cars and those were easy to maintain.
Thanks in advance.
Hi jkoya!
My name is Mike, and I am the owner of Appearance Solutions in Sacramento, CA. We have been working with the XPEL Stealth film for almost 10 years now, and would be happy to share our experience with the film and the best way to care and maintain it.
As you already know, XPEL Stealth will give your Model 3 a unique look that isn’t too crazy or over the top. Your significant other, or whoever else will be riding in the car with you, won’t be embarrassed to be seen in the car! With the standard XPEL Ultimate paint protection film, care and maintenance is pretty straightforward. It’s important to note, satin film is a little more sensitive to pollution, bug splatter, bird bombs, tree sap, and water spots. As long as you are mindful of this, care and maintenance can be a breeze and the film can last 10+ years (one of our current clients has a 2011 frozen gray m3 that we put on back in 2011 and the film still looks like the day we installed it)! We have also had great success with coating the film because of the sensitivity of the finish.
Having the right “tools” for the job will make your life much easier.
We have several go-to cleaning products that we use for matte/satin finishes. If there are stains on the film, you will want to start with 90% isopropyl (IPA). Rub with light pressure and never push too hard or move too fast. Let the IPA soak and work for you. This is the safest solution, but for a more stubborn stain you can step it up to lacquer thinner (this is safe too, but unnecessary if the isopropyl works). Again, don’t rub too hard.
For wash soaps, we like Chemical Guys Meticulous Matte Auto Wash for Satin Finish & Matte Finish Paint. Normal soaps aren’t formulated for matte/satin finish and may cause unwanted gloss or shine. This soap has great lubricity for encapsulating dirt/debris and is also pH-balanced.
If you don’t coat the film, you are going to want to use a matte/satin finish sealant. XPEL has a product that is specifically engineered for its film and others like it. It is called XPEL Flawless Finish Paint Protection Film Sealant. Be sure to apply it in a uniform manner, and not the “wax on, wax off” motion you may be accustomed to. I recommend a back and fourth motion instead. Because the film has a non-glossy finish, light reflects differently and the flat finish allows you to see all the high spots/marks. If this happens, apply a fresh layer of sealant and wipe right away. Be sure to always work on one panel at a time. DO NOT apply to the entire vehicle at once.
If you have any further questions, feel free to reach out anytime. I would be happy to share more details with you. I can be reached at
(916) 402-9325.
Best of luck!
Mike
[Deep Blue Metallic with XPEL Stealth]
This is the only Deep Blue Metallic we have done in XPEL Stealth, and this is the only picture I could find of it. This is a WORK in PROGRESS, but I wanted to show the color in Stealth. I promise the car did not get delivered like this!
[Other Model 3's with XPEL Stealth]
