Xpel Wrapping and Removing Side Cameras
DocNartman
7
5
Sacramento
Decided to get my new MX100D fully wrapped. Found a highly recommended group locally that can do the work. I can see from many others that sensors won't be an issue if done correctly (i.e., cut outs for the ultrasonic sensors, etc).
Quick question, noticed these places remove the side cameras/blinkers. Any issues with this? Would the car need autopilot to recalibrate after they reinstall the cameras? Did some searches on these forums (Xpel, Wrap, Cameras) and couldn't find anything. I'm assuming all is good.
Loving the MX thus far!
chudiddy
82
63
NE PA
I did my wrap myself and its quite simple to remove the cameras. No need to recalibrate. Are you doing the chrome delete? It's a must IMO. The side mirrors are a pain in the butt with how they fold and all. Tough to get the entire mirror in one piece. Good luck and post pics when complete.
Premiertint
Local Vendor - NorCal
Sep 6, 2018
184
125
El Dorado Hills , CA
Agreed. no re-calibration needed. We pull the side cameras, wrap the full fenders, and pop them back in afterwards. Done a lot these without ever having an issue. Sorry that we didn't get your business though. El Dorado Hills isn't that far away. Keep us in mind next time or for your window tinting needs too.
MrMannnilow
80
44
My chrome piece is loose on my driver's side repater. It appears there might be double side adhesive there. Anyone have any ideas how to secure it so it doesn't get pulled off in the car wash?
Premiertint
Sep 6, 2018
184
125
The fender camera/sensor are not supposed to have double sided adhesive holding them in. There are 4 plastic clips that hold them in very tightly. They should not be loose at all.
We remove them hide the edges of the Paint Protection Film for a cleaner finished result.
Reactions: EliteFinish
MrMannnilow
80
44
Not the sensor or assembly itself, just the chrome trim across the top. If that's the case then it must be glued. Either way mobile service is taking care of it. As if 2 weeks ago the part is on order
EliteFinish
Local Vendor - SoCal
Mar 11, 2013
144
89
San Diego, CA
We remove those side cameras for install on every M3/MS/MX that receives a front end package (meaning the full fenders get PPF). Have not had an issue once. Estimate 2000+ vehicles. The process is fairly straightforward, and for the most invisible install possible we recommend removing them to get film behind it.
-Kevin
artc1688
New Member
Jun 18, 2019
2
0
97229
Doc, i will be in Folsom are tomorrow and looking to wrap my MX.
do you have any recommendations? cost? how long did it takes?
feel free to email me at 503-880-6991
thx Art
Ozzie66
47
4
Virginia
So, is it possible for the ppf to be installed appropriately without removing the side camera's?
I just saw my install leave them in. I do not believe that they can successfully wrap the edges in the fender port. Thoughts?
Silicon Desert
3,038
2,794
Sparks Nevada / GF 1
Thank you for your answer. I was concerned that they would not be able to wrap the edger of the film so it would not fray
Well, mine was wrapped 4 years ago and still holding fine, so I guess it comes down to how good of a job they do. I think it looks great the way it is. I can hardly even notice where the edges of the wrap end.
Premiertint
Sep 6, 2018
184
125
Wait, "CAN you install PPF on the front fenders without removing the cameras AND still have it look AS GOOD AS POSSIBLE?"
My answer is "no". When you are a reputable shop that KNOWS these vehicles and KNOWS how to correctly remove and reinstall the cameras without causing any issues, then that is what you do. If you do not take this very easy extra step, you will need to rely on the computer cut plotter pattern. These patterns are usually very good and quite accurate...but NOT the best possible installation. YOU WILL SEE THE EDGES OF THE MATERIAL AROUND THAT CAMERA. If you are aiming for "good enough", then you will be happy. If your standards are higher, then confirm that the shop WILL be removing the cameras and confirm that you do not want to see the edges of the material around the cameras. If they say they will remove the cameras, then let them do their job. If they sell you on how great their patterns are and that you will "barely see..." then they are a "good enough" shop.
As for the concern for the "fray", it is 100% the shop's responsibility to make sure this doesn't happen.
Ozzie66
47
4
Virginia
my answer is "no". When you are a reputable shop that KNOWS these vehicles and KNOWS how to correctly remove and reinstall the cameras without causing any issues, then that is what you do. If you do not take this very easy extra step, you will need to rely on the computer cut plotter pattern. These patterns are usually very good and quite accurate...but NOT the best possible installation. YOU WILL SEE THE EDGES OF THE MATERIAL AROUND THAT CAMERA. If you are aiming for "good enough", then you will be happy. If your standards are higher, then confirm that the shop WILL be removing the cameras and confirm that you do not want to see the edges of the material around the cameras. If they say they will remove the cameras, then let them do their job. If they sell you on how great their patterns are and that you will "barely see..." then they are a "good enough" shop.
As for the concern for the "fray", it the 100% the shop's responsibility to make sure this doesn't happen.
Thanks much.
Ozzie66
47
4
Virginia
Thats tremendous. Thank you for your counsel. Im picking it up today, and will report back. Thanks again.
