Y with 21 inch 7k miles and rear tires almost worn out?
Discussion in 'Model Y' started by Larryfl1, Oct 6, 2020.
  1. Larryfl1
    Larryfl1 Member
    Florida
    I have only 7k miles and my rear tires on the 21 inch are almost worn out...kind of crazy
    What’s my options different tires? Recommendations?
    Or go to 19 or 21 inch after market???
  2. jb401
    jb401 Member
    Chicago, IL
    oof. go 19". those 21s are so expensive to replace
  3. Larryfl1
    Larryfl1 Member
    Florida
    I’m thinking of going with 20 inch aftermarket all season...
    I assume the ride will smooth out somewhat?
    Only downside is Tesla roadside wont take care of the wheel/tire if needed since its aftermarket
  4. N1L CO2
    N1L CO2 Member
    OC, CA
    Not surprised to see this at all. Especially how fun it must be to mash the pedal on the Perf model (I have the non-perf). The 21" tires are probably rated to last ~ 20k miles - if you are careful. Going to 20" all-season is a smart move. The ride comfort will be enhanced while noise level will go down. Those 20" Induction wheels are going to become very scarce in the pre-owned market. :D
  5. Larryfl1
    Larryfl1 Member
    Florida
    How expensive are the 20 inch to buy from Tesla with tires?
  6. N1L CO2
    N1L CO2 Member
    OC, CA
    Seeing how the OEM 21" wheels are $700-800 per wheel, Tesla will easily charge $500 a wheel plus the cost of the tire. And the crappy thing is, for that much money, there are much better aftermarket choices out there.
    Flow-formed/forged wheels are about $400-500 a wheel. They are much lighter than that of their OEM counter part by at least 10lbs which will help with range too. Lighter wheel = less unsprung mass for the motor to turn hence using less energy. I think Tsportline just came out with a new 20" wheel that resembles the Uberturbines.
    With that said, I would just carry a puncture fix kit in the car for roadside troubles. As long as you don't mess with the TPMS, any tire shop will be able to service wheels/tires.
  7. mac9899
    mac9899 Member
    Florida
    A little over $4000. Go for the 19" OEMS already a lot on eBay for about 2k. That's what I'm doing and save the 21" for certain events etc....
  8. N1L CO2
    N1L CO2 Member
    OC, CA
    Day~um!! That's larceny! :eek:
  9. Larryfl1
    Larryfl1 Member
    Florida
    Is there any better choice to replace the 21 inch tire that will last longer?
  10. Ruffles
    Ruffles Member
    Snohomish WA
    Michelin is supposed to be releasing an all season pilot in the 21" but I don't know if its made it to stores yet.
  11. Larryfl1
    Larryfl1 Member
    Florida
    That sounds interesting that could give the higher mileage
    If that is the case i may just replace the rears in about 2k miles as they will be shot..fronts look very good still.
    That would get me going for another 8+k miles for only 2 tires... then go to the all season when they release them...
    I assume the all season will have a substantially higher tread wear rating
  12. Picasso
    Picasso kllkkjlk
    how are the tires wearing? did you unmount and rotate or even feel the need to?
  13. TomServo
    TomServo Active Member
    Belleville IL
    To coin a phrase I heard all the time from my Corvette days - if you want to play, you've got to pay.
    • Like x 4
  14. yossi
    yossi Member
    brooklyn
    yokohoma ADVAN Sport A/S+
    265 /35 R21 101Y XL BSW
    and 245 for the front
    that will save you$$ 1k 4 tires thats the only option in 21"
  15. Raro
    Raro Member
    Los Angeles
    "No money, no honey" :)
  16. Lozzy
    Lozzy Member
    NC
    The tires can’t be rotated, they are directional and staggered
  17. Lozzy
    Lozzy Member
    NC
    The Michelin Pilot Sport All Season 4 is already released for the rears and I read the front tires are on the way. I believe they are already on the Michelin Canada site so they can’t be too far out.
  18. Larryfl1
    Larryfl1 Member
    Florida
    I assume there would be no dramatic ride change with these? I drive normal every day..sometimes hit the acceleration hard but not going on any track or crazy screaming curve/turns.....
  19. Larryfl1
    Larryfl1 Member
    Florida
    Has anyone actually tried these yet on the y Performance? Would love some review/opinions...
    Overall would like to have tires that can pull 15k at least on wear and maybe slightly softer ride (make my wife happy)
  20. Lozzy
    Lozzy Member
    NC
    I don’t have any experience with the tires but the sidewall is going to be stiff on any tire with a 35 ratio. I wouldn’t expect a great gain in ride comfort with any 35/21. They should wear much better than the P-Zeros but I can’t say that for sure.
