Y with 21 inch 7k miles and rear tires almost worn out?
Discussion in 'Model Y' started by Larryfl1, Oct 6, 2020.
  1. yossi
    yossi Member
    brooklyn
    i have the
    i have these on 255/40-20 YOKOHAMA PARADA SPEC X after i replaced my 21 and i am really happy
    the ride comfort should get better but not so much since the P zero are really hard tires i learned that after i took them off and compare them
    with the YOKO
  2. imola.zhp
    imola.zhp Member
    Memphis
    Not that I would assume OP did this but this is, in part, why I wont Turo my Tesla when I get it. That income sure sounds great until your tires are mysteriously worn out prematurely. Someone had a good time!
  3. Lozzy
    Lozzy Member
    NC
    #23 Lozzy, Oct 7, 2020
    The P Zero is a higher load rating, that could be a contributor to the stiffness of the sidewall.
  4. DaveORD
    DaveORD Member
    Chicagoland
    I'd say being a run flat tire will not help either...
  5. NaiWiste
    NaiWiste Member
    Bay Area
    Would there be any difference in road comfort if I switched from the Pirelli P Zero 21" to the Michelin Pilot Sport 4S? Tirerack gave the Pilot Sport 4S a score of 9.0 in Comfort Performance and the P Zero a 7.9. Wondering if anyone had any experience with the PS4's.
    Riding in these P Zero tires feels super harsh and abrasive.
  6. TLLMRRJ
    TLLMRRJ Active Member
    Houston
    #26 TLLMRRJ, Oct 7, 2020
    Almost certainly you have an alignment issue to only get 7K miles out of the rear tires. No, it's not the weight of the car. No, it's not the power of the car. No, it's not soft tires. No, it's not the driving style.
    Listen up boys, have you not read thread after thread after thread of build quality issues with Tesla where the factory was lazy and sloppy??
    Why in the world would you think that Tesla would overlook the opportunity to screw up the wheel alignments in their factory??
  7. schristo43
    schristo43 Member
    Washington
    I just rotated my 21 Uberturbines and checked wear after 7k miles... all were wearing uniformly and I had more than 8/32 everywhere. They start at 10/32 so I anticipate getting a bit more than 20k out of them. Planing to give the Pilot Sport 4S a try then.
  8. NaiWiste
    NaiWiste Member
    Bay Area
    @schristo43 Did you just rotate them from left to right? The Pilot Sport 4S are a bit cheaper and seem to be better overall.
  9. Lozzy
    Lozzy Member
    NC
    The Michelins have a better reputation. Try dropping to 40 psi if you haven’t yet. Either way it’s a harsh ride on the 21s. I’ve gotten used to it but I’ll be buying coilovers and lighter wheels in the future.
  10. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    Are all 4 tires worn? Is the wear even or one part of the tire(s)?
    I feel mine has a toe issue with alignment, so Im expecting the fronts to wear quickly.
  11. S3XYCarMD
    S3XYCarMD Member
    Maryland
    I am definitely waiting for the Pilot Sport A/S 4's to come to 255/35/21, as noted earlier they are available in canada and we have them already in 275/35/21 so hopefully it will be available soon. As someone in a mid-latitude where we only get snow a few times a year but have plenty of time below 40 degrees (I'm in Maryland), A/S tires just make the most sense as you shouldn't really stay on summers all winter but it's not worth the hassel of having dedicated winter tires for the few times you might need that extra traction. I previously had the A/S 3+, very very good tire (as is the continental DWS 06 but those aren't available in our size). Also, the A/S 4 will most definitely have a longer treadlife than P Zero, and has more than enough handling for normal spirited driving though I'm certain the Pirellis (or Pilot Sport 4 for Michelin) would have more grip at the limit, I never (intentionally) see the limit.
  12. UT4EVER
    UT4EVER Member
    Georgia
    I’ve got 5700 miles on mine and they still look new.
    This is exactly my experience. My stats are almost identical. I actually had Tesla mobile service today (homelink installation) and the service rep said my tires were in excellent shape. He said I should expect 15-20k with no problems.
  13. Larryfl1
    Larryfl1 Member
    Florida
    I just checked...both rears are substantially worn. The fronts appear to be almost like new... plenty of tread
    I dont understand what would cause the rears to wear like that... most cars i have had the fronts wear fast...
    My SC said regenerative braking wears tires..not sure how that can be...
  14. schristo43
    schristo43 Member
    Washington
    That's the only way you can rotate a staggered set...
  15. AKTech.it
    AKTech.it Member
    Texas
    Wow, you must have a heavy foot! Mostly highway driving here, 11k miles and the tires still have 7/32nd left on them
  16. AKTech.it
    AKTech.it Member
    Texas
    Proper way to rotate is side-to-side.
  17. imola.zhp
    imola.zhp Member
    Memphis
    Which cannot be done with directional tires without dismounting and remounting the tires. “Side to side” rotation only works with non-directional tires.
  18. N1L CO2
    N1L CO2 Member
    OC, CA
    Yes, you can. I believe the 21" OEM tires are asymmetric and are marked with (Outside) stamp on the wall so left to right rotation is allowed. There are directional tires marked with (left/right) on the wall but not really that common anymore because you can only rotate them front to rear, provided that you don't have a staggered setup.
  19. Larryfl1
    Larryfl1 Member
    Florida
    It doesnt really make sense..i am not driving the car hard to see that kind of difference...also it is only the rears the fronts look great....
    Also i live in florida where almost all the roads are straight...so its not like I’m curving at high speeds....
  20. everydaychris
    everydaychris Member
    what the. how much did you drive bruv?
