yes, I mind the Gap
Discussion in 'Model S: Interior & Exterior' started by scottm, Jul 19, 2016.
  1. scottm
    scottm Active Member
    Canada
    #1 scottm, Jul 19, 2016
    The model S is a bit gappy on the fit and finish scale along seams between adjacent body panels.
    They do a good job where front door trailing edge meets B pillar. But I felt they should have carried out more of this treatment throughout the car.
    So I filled in the gaps with a weather stripping obtained at Home Depot.
    This helps:
    - wind noise
    - moisture and dirt entry
    - aerodynamics in a small way
    - appearance
    Much more premium look to the car.. take a look!!
    Here is where A-pillar meets fender:
    Here is where hood meets fender:
    Here is where hatch meets rear quarter panel:
    Here is hatch near tail lights. Look closely and you'll see a double layer thing going on. I used two different materials here because the gap is large.
    Here is open hatch... You'll notice where I put down a strip of "pickup truck box liner for canopy" or whatever they call it on the quarter panel. And I ran the same weatherstripping as the other places along the hatch door itself. So these material sandwich together when the hatch closes.
  2. scottm
    Canada
    #2 scottm, Jul 19, 2016
  3. scottm
    Canada
    A note on the rear hatch. There's a pinch sensor strip that runs along the side edges of the hatch door, for power lift gate option. If you press this strip when hatch is closing it will stop.
    Here you can see where the pinch sensor meets the foam truck liner tape. There is still some squish room remaining under this tape. If you build up the thickness too much here the pinch sensor may trip and you won't get a full door hatch closure. Allow the pinch strips to just meet your insulation materials, but not be triggered by it!
  4. jelloslug
    jelloslug Active Member
    Greenville, SC
  5. FlatSix911
    FlatSix911 918 Hybrid
    Silicon Valley
    Well done! I have wind noise issues with the window seals ... any suggestions?
  6. scottm
    Canada
    .. drive slower :p
